-   -   Longhood vs IB handling: What year transitions most significantly? (http://forums.pelicanparts.com/porsche-911-technical-forum/1082035-longhood-vs-ib-handling-what-year-transitions-most-significantly.html)
Shaun @ Tru6 01-02-2021 03:06 PM
I am an acolyte of Colin Chapman, the man who said “Simplify, then add lightness” and “Adding power makes you faster on the straights; subtracting weight makes you faster everywhere”.
Porsche kept adding more and thicker sheet metal to the unibodies over the years so while your car is breathtakingly amazing, a true owner's build, it will never be a light car.
Of all the cars I have owned and currently own, nothing touches my '73 with a 3.2 and headers weighing in at 2174 lb in terms of fun. You can drive it at 7/10s on public roads all day long with a huge smile on your face. But that's not a car for you. It's essentially a single fixed back Momo inside a chunk of steel with a hot 3.2 riding on 15s and a decent suspension. The absolutely most fun car I've ever owned and that includes a lightened M491, 69E, and lightened 84 Targa.
If you want a truly fun car, get a 74 or 75, add as much lightness as possible stripping it, backdate it, figure out what you need to make 220hp with some torque, then start adding comfort, otherwise known as weight, back in, to make it livable and enjoyable.
47silver 01-02-2021 05:13 PM
72 vs 75
my son has a 72T, i have a 75 S.
1. the mfi sound of the 72 is hard to beat.
2. the 72 is a bit lighter at speed and on the highway i prefer the 75.0
3. I actually prefer driving the 75. though the 72 is in near perfect condition.
Maxhouse97 01-02-2021 06:35 PM
Thanks Bill I will try taking out the spare. I have hesitated in the past due to the number of things I’ve read about not getting the front end too light in comparison to the back for handling balance. But will see how this goes.
Interesting to hear you say that maybe I should stick with my 17s ... I assume the torque costs you refer to being low are due to the light weight of the wheels. And yes I love my brakes, have thought about going back to stock 3.2 brakes or even base Boxster calipers on 3.2 discs to fit 15s, but I would be down grading in capability.
This is also where aesthetics crosses over with performance - if I backdate I wouldn’t want to keep the 17s, I just don’t think they look right on a longhood. I’ve already got euro bumper tubes and took out the fog lights, so if I keep the IBs next step would be FG and I don't know how in feel about those.
Evan Fullerton 01-02-2021 08:16 PM
Im in the middle of a g50 swap on my car so I though these 915 vs g50 weight difference might be interesting in this tread.
Mag case ‘75 8-31 915 with SC mainshaft, AL side cover and nose cone, Guard LSD and WEVO spray bar cooling setup, 100mm output flanges. 107lbs
G50 with open diff. 142lbs
915 torque tube 11.8lbs
G50 torque tube 19.6lbs
The g50 aluminum trans mount might be a couple pounds lighter but the 108mm CV joints are a bit heavier then the 100mm ‘75-‘84 cars use.
I think once I get a LSD in the g50, it probably is a going to be between 50 and 60lb weight gain irrespective of the clutch and flywheel for the swap.
70SWT 01-03-2021 07:45 AM
The bottom line to me, from years now of owning both longhood LWB cars (never owned a SWB driver or a G50 car) and G-bodies, is that the longhood cars come with the Miata feel right out of the box. Pre-Carrera G-series cars can get there with some focused lightweighting.
These chassis were mostly the same across time. Sure, they were beefed up in the name of structural improvement over time, but at the chassis level, it's not massive (said from having weighed a number of stripped chassis over the years). Key items that are somewhat bulky include the impact bumper mount plates - but these are easily removed with some tools, elbow grease and and afternoon.
Otherwise, it's mainly the bolt-on stuff that makes the noticeable difference to anyone with sub-Rohrl senses. The later the car, the more they evolved into the yuppy '80s and safety era, when Porsche added more luxury, bling and features than die-hard enthusiasts necessarily wanted. The toughest call to me is the unsprung weight issue. I love wide wheels, I hate the weight.
So, today, it just becomes a question of how silly you care to get with the G-bodies in the name of light weight to get that nimble feel.
I am willing to get pretty silly, and I got tired of fixing rust over the course of owning a series of (much-loved!) longhoods, so I am in the G camp for now.
Bill Verburg 01-03-2021 09:05 AM
Originally Posted by Maxhouse97 (Post 11164327)
T....
T...
While weight of the rotating components does matter, by far the more important one is the radius followed by any mass at the extremes of radii, tires are the heaviest and have most mass furthest from the axis of rotation
I've posted many comparisons of these effects, Ill try to do another for you later
in 17 the most efficient yet effective tire sets will be 215/45//245/40, for a more powerful car like a 3.6 conversion 225/45//255/40 or if you could find them 225/40//265/35. The 215/45//245/40 is going to be more efficient than all 16 sets except for the 205/50//225/45
in 16 205/50//225/45 is the most efficient and effective setup, followed by 205/50//245/45,
in 15 205/50//225/50 or 205/50// 225/45 or 225/45//245/40
In all cased tire radius and handling balance and grip and grip level desired and fit are the primary factors to consider. All take precedence over any individual weight metric.
looks are a personal thing, you will have to make your own decision there
as for brakes, if you go smaller the 3.2 Carrera front w/ pre '84 rear and no p/v is the way to go, 23.8 mm m/c can be used w/ them but expect to need a lot more leg, some guys even do this w/o boost.
other than that only full 930s are an upgrade that work w/ 15s, Possibly some aftermarkets but none that I am familiar w/
chrismorse 01-03-2021 09:25 AM
some low hanging fruit
A couple of gignificant losses can be had by ditching the 50 gallon windshield washer tank and the enormous stock battery, all left side forward items.
If your car is a DD, as opposed to a track car, i would think twice about ditching the bumpers. In the last year, i had a couple of "Taps", one rear ended, no damage to the work truck, the other in a parking lot. Without the bumpers you could be in for some serious repairs. I heard of one 911, w/ FG bumper getting tapped and it broke his crankshaft.
Glad they didn't hit the 74.
Bill Verburg 01-03-2021 09:45 AM
Here's a generalized summary of what fits(or can be made to fit) an SC/Carrera body car
inertial and gearing costs go down the shorter the tire
http://forums.pelicanparts.com/uploa...1609695003.jpg
Here's a comparison of an efficient 15(not the most efficient though) to the most efficient 16" Fuchs setup
Here's comparison of the most efficient Fuchs16 setup to the most efficient Fikse 17
It may be a little hard to read but the above 17 only has <6lb-ft cost wrt to an efficient, though not the most efficient 15 setup
Lastly here's a comparison using the same tire lines, efficient 16 vs efficient 17 A052s, here the weight of the rear tires does make a big difference, all data comes from factory #s
http://forums.pelicanparts.com/uploa...1609695662.jpg
One more thing, backdating to early long hood isn' t the only way to lose weight in the ends
There is the Ruf look, The RSR look w/ Carrera chassis and the SC/RS look w/ Carrera chassis
paul_howey 01-03-2021 01:29 PM
^ This x100.
SalazarS2K 01-03-2021 01:50 PM
Originally Posted by Maxhouse97 (Post 11163543)
Great responses, thanks for this. Here’s some more detail on my car from my valuing thread relative to weight savings I’ve already incorporated:
132,804 miles
- Steel synchros in trans rebuild by Brian Copan BMC & G at 119k miles, New clutch, KEP Lightweight aluminum pressure plate, new G50 clutch cross shaft kit
- Full 996 brake conversion with new front hubs to accommodate OE 996 front rotors, upgraded 23mm master cylinder
- Full Suspension rebuild: All new ER bushings, all new wheel bearing, new ball joints, bump steer kit, RSR 19mm lowered spindles, Tarett adjustable sway bar, Elephant racing custom valves shocks, drop links, turbo tie rods, full corner balance and aggressive street alignment
- Upgraded torsion bars 22/29 mm, hollow in rear
- Carrera front valence
- Bob Stratton duck tail
- Safety Devices roll cage
- J West Rennshift shifter and G50 coupler rubber bushing
- Steve Wong custom 93 octane chip
- Additional outlet stock exhaust
- Fabspeed cat delete (have stock cat)
- Removed a/c
- Heater backdate (have stock parts)
- K&N air filter and drilled air box
- Momo deep dish steering wheel
- TRE 917 style shift knob
- Recaro PP seats, custom leather and Alcantara covering, rennline seat belt anchors and sub strap
- Rennline triangular strut tower brace
- Rennline battery RE-location kit plus lightweight battery
- Aluminum foot rests
- H4 headlights with upgraded relays
- Fikse/Zuffenhaus forged wheels 17”
- Wevo engine mounts
- Magnecor plug wires
- Webcam 20/21 camshafts
- Recent refresh (piston rings, steel head studs, etc) at 131k. miles. Stuttgart Services, Louisville KY. New engine sound pad. Rebuilt valve guides at 88k.
- Euro bumperettes, lightweight Euro bumper shocks (minus bumper shock tow hook), Bosch euro taillights
- Custom interior refinish with carpet/sound insulation
- 996 aluminum spare tire
After this thread I’m really thinking of going down to 15” or 16” wheels with narrower tires. Right now I’m on 225/245 17s. Then you start looking at a backdate for both aesthetic and weight reasons.
http://forums.pelicanparts.com/uploa...1609590085.jpg
Max- Your car looks great as is. I think it’s a nice balance between the classic look with the modern wheels and buckets. Have you autocrossed the car before? You can play around with wheel tire combos to see if the small tires will improve the feel of the steering at the limit. You also give up compromises if you sell this car and go to an earlier car as you would have to rebuild it again into the hot rod you have now.
RWebb 01-03-2021 05:01 PM
did Porsche really use thicker sheet metal in the unibodies over the years?
Maxhouse97 01-03-2021 06:00 PM
Thanks again Bill. I guess I have to decide the best combination of aesthetics and performance. If I stay with some form of Impact bumper I will stay with the 17s. If I go backdate I will probably go 15s.
There is a chance I could go in 16 205/50//225/45 ... 16” wheels radially clear my current 996 brakes, it’s just the taper of the standard Fuchs barrel that doesn’t work. If I can find some custom Fuchs replicas with less taper I could stay with 16s and keep my current brakes.
Thanks Salazar, I have tracked but not autocross. I would like to try smaller tires, both for the effect Bill is describing and for the shorter gearing.
Maxhouse97 01-03-2021 06:05 PM
BTW sorry to get mushy on you guys but I love this forum. I’ve been on many different forums over the years and to have to say this thread is an example of how helpful and encouraging the members are here. I’ve been on here since 2007 and the same great people come back to give in depth advice. I have now decided to keep my 87, and one of the reasons is so I can interact with the great people on this forum.
kach22i 01-04-2021 08:04 AM
I doubt it, the trend in those years was the opposite.
Allegedly one of the main reasons pressuring the halt of VW Beetle production was the thicker sheet metal was getting rare (newer designs using thinner metal) and cost going up. The large curves with no supporting frame under them needed old fashion thick sheet metal that was out of vogue.
At least that's what I recall of a rumor in the late 1970's and or early 1980's.
More flexible higher carbon steel (crush zones) over the stiffer low carbon variety or something like that, the matrix blend changing.
Then again, was it something to do with magnesium?
1950: The metal is magnesium, the car is the Beetle
Porsche went back and forth with magnesium and aluminum for their blocks, how could cost not be a consideration?
Before China flooded the market with cheap magnesium it was getting to be an expensive material.
paul_howey 01-04-2021 12:40 PM
+1 if there is a weight increase in bare chassis is likely due to added reinforcements and increased galvanization which I would argue is a positive and not a negative. Those are places I'm happy to deal with the added weight.
The extra weight (that actually makes a difference) over the years comes from all of the items already discussed in this thread. If you are building a hotrod these days, you are better off with a later year car, take it down to the chassis and add in only what you want/need based on your preferences. It really doesn't matter if you start with a 73', 77', or 87'.
pmax 01-04-2021 01:52 PM
I doubt it given the costs of retooling.
I believe reinforcements were added in the 80s to the chassis, doors etc and that galvanization added more mass as well which at the end of the day improves safety.
targa72e 01-07-2021 01:30 PM
If you want to keep the late bumpers you can replace the bumper shocks with Aluminum tubes and either replace rear bumper pads with Euro units or remove them for some weight reduction.
john
dwelle 01-07-2021 01:44 PM
FG bumper blades are available from getty as well. i'm fitting a set to my '74 as we speak. 1st year IB car, so i want to keep the bellows and narrow bumperettes, but i'm also trying to hit 2100 lbs. i fab'd up some aluminum to replace the crush tubes, they weigh almost nothing.
we shall see...
Larmo63 01-07-2021 06:45 PM
I was surprised how light the impact bumper blades actually are. I wonder if the look of the FG units can be detected after paint? I considered using those when I did my "un-hot-rodding" of my car.
I used the RennLine struts and narrow rear guards (my car is ROW) so appropriate. I tried to think light on everything. I didn't notice any loss of fun or power with the slight added weight.
I used to not run a spare at all, but now that it's in there, no big difference.
As I get older, maybe I don't drive as fast?
Maxhouse97 01-07-2021 07:04 PM
Can you share a pic Lawrence?
