-   -   Longhood vs IB handling: What year transitions most significantly? (http://forums.pelicanparts.com/porsche-911-technical-forum/1082035-longhood-vs-ib-handling-what-year-transitions-most-significantly.html)
Maxhouse97 12-29-2020 07:06 PM
I own an 87 that I may be regrettably selling (see nearby thread), and was thinking that I might want to move next to a longhood. The main thing I would be looking for is that true lightweight, go-kart type handling and fun-to-drive characteristic.
Question is could I get close to this by buying a 74 instead of a longhood to increase availability and save money? I drove a 74 once and it felt like a Miata compared to my 87 (87 has 225/245 x 17” tires). I tried to lighten my 87 (got it down to 2600) to get to this feeling, but it never quite got there. I’ve read that G-bodies can never approach a longhood for that tossability ... not sure why.
So what year range does the above characteristic change? Is it the 2.7 cars? Can you get an SC close? Or do I need to get a true longhood?
AFB24911S 12-29-2020 08:19 PM
I've had a 1977 911 S Targa for about 2 years now, and I test drove it back-to-back with an '86 Targa and a brand new Miata for that exact reason. The 911 felt lighter, peppier, and just as go-karty. It wasn't modified at all, and it had 205k miles on it when I bought it. The 2.7 revved a lot more eagerly, changed direction quicker, and still felt fast in a straight line.
I was living in California at the time and had the luxury of test driving a bunch of unique cars, but I would still suggest driving your (super cool!) 911 to test drive a 2.7 and a long hood if you get the chance. No idea what a long hood car is like. I have heard that the 1973.5 fuel injected cars are something truly special.
Arne2 12-29-2020 08:50 PM
I went from an '84 coupe to a '72 911T. The long hood is far more interactive and responsive. I believe the mid-year cars ('74-77) feel lighter than the SC/Carreras mostly due to the narrower tires. With wider, heavier wheels and tires they feel more like an SC or Carrera. Beyond the tire difference, the biggest difference is the polar inertia. The extra weight on a short hood car is at the very far ends of the car. That bumper weight makes the IB cars less responsive to changing direction.
356911930 12-29-2020 08:58 PM
Yes! You will be very happy with the 1974. Get one and make it your own. A little lighter, a little suspension and engine work and you will have exactly whatyou are looking for.
Best of luck,
Rahl
Hi_Fi_Guy 12-29-2020 09:00 PM
I’ve only driven the 1984-88 cars and 1969-73 cars and for me there was no comparison, I had to own the earlier car. No regrets. Enjoy every drive.
ChrisHoover 12-29-2020 09:36 PM
I've only driven my Cayman and my 65. The Cayman is heavier, it has electric stuff, its scary fast to me, it starts every time, has heated seats and a crappy nav system. It is fun and comfortable.
My old car is long hooded, short wheel based, flat sided, and skinny tired. It is very light, mostly starts, is all mechanical and by throwing the forward lever, you ankles will get warm. It is slower than the Cayman but it is more fun. I've have yet to purposely slide it although over the summer I did slide right through a turn that was a bit unnerving yet exhilarating.
I have never driven a Miata but I had 72 510. I drove the hell out of the 510 sliding all over the rural county I lived in. The 510 was very light and 90hp. It was so much fun to drive. My old Porsche is a lot that old 510 only a little more sophisticated and a little more quirky.
Evan Fullerton 12-30-2020 12:38 AM
1972 first year of the 915 gear box
1976 was the last year of the manual brakes
1978 I believe is when the clutch arm gained the Omega Spring
1987 first year of the g50 gearbox, hydraulic clutch, and crazy heavy stock flywheel/clutch setup
Anything pre '72 with a 901 trans and stock engine feels very different with no torque. The '72 2.4 was the first car that had some grunt.
The change to boosted brakes is pretty significant in my mind on the driving feel and one I am not fond of.
The lighter over center clutch feel of the cars with the Omega spring also removes some of the early 911 feel.
The suspension setup really didn't change much from '73 or so onwards but the cars got heavier and softer controls, taller gearing, and heavier wheels and tires all of which detract from the raw engaging feel of the early cars.
Maxhouse97 12-30-2020 04:41 AM
Great comments - thanks for the kind words. I guess the main point to focus on is the difference between 73 vs 74-77. If you aren’t worried about originality, can you build a car with a nice longhood conversion that drove like the 73? If you can a whole number of great cars open up to you at a much better price, leaving more room for tasteful mods.
I have to do some research on the differences here, but I’m not as worried about technical details but rather how they feel. Again the car I drove was a 74 and it certainly felt this way. But I haven’t driven a 73.
paul_howey 12-30-2020 05:02 AM
You can get your 87’ where you want it but you are looking at a full backdate of the body work (long hood conversion) and losing weight anywhere else that you can.
The pre-74’ cars are great but after a few months you will likely want to make some updates coming from an 87-89 car.
You also have arguably one of the best transmissions Porsche built and the weight differences compared to a 915 is not that much more. I believe the numbers for the G50 vs 915 are 16lbs heavier on the transmission itself and 11lbs heavier on the clutch. The flywheel should be the same weight.
The bottomline is that you have a lot investing in your 87’ and for a little bit more, you can probably get it where you want it to be. My recommendation would be to get some seat time in a few older cars and take notes about what you prefer about them and then apply it. These cars are fundamentally the same and it’s just a matter of removing/adding the right components.
The 87-89 cars are arguably some of the best 911’s mechanically but they have a lot of unnecessary bloat. I think you have a good car that can get you what you want but that’s just my .02
JonT 12-30-2020 06:31 AM
interesting thread. My 80SC has full suspension update with bigger torsion bars, bigger sways, and revalved Bilsteins, 225fr/255/r tires, and feels very responsive. I've never driven a pre-SC 911 to compare. Maybe sometimes its better to not know what you're missing.
paul_howey 12-30-2020 07:16 AM
The short answer is that "yes" you can accomplish this. The problem is that once you start down this slippery slope the tendency is to make everything (suspension, motor, brakes, etc) the best that it can be and you will end up with an amazing feeling/driving car but it also won't feel like a pre-74' car.
I guess the first order of business would be to get some seat time in a pre-74' and see if you like how it drives. Based on your current list of mods, I think you will like the lightness and the sound of a 73' and earlier car but that might be about it. I personally love the look of the long hoods (hence why I did the conversion on mine) but I also wanted the car to feel confident on the road so I have a list of mods similar to yours.
Personally, I think a long hood conversion/backdate (will lose a lot of weight), SSI's w/ 2 in - 2 out muffler (wakes up the 3.2 big-time and sounds amazing), and a bit more weight reduction will get you where you want to be.
My prediction and I could be wrong, is that you will sell the 87' for 55-65k which will be enough for a 70-73 911 T driver condition car that you are then going to respend a lot of the same money to "update" (suspension, brakes, etc) as well as fix any little issues. So at the end of the day, it will still end up driving more like a 74'+ 911 anyway.
If you do decide to go the conversion route, feel free to PM me. I can give some advice on what to do and (more importantly) what not to do.
RWebb 12-30-2020 11:04 AM
'74 will drive like a LWB early car and is a lot cheaper - is or was the real value proposition since everybody hated the Mg case, but the '74s escaped thermal reactors - buyers may have caught on to that by now
SWB will feel more like a Go-Cart, and will spin more easily
RS60 is what the go carters really want but many settle for a 914 or 914/6
my ultimate 911 would be a '72 body with the wonderful road-racing shift pattern & nice, light feeling type 911 trans (often called 901) and lightened, then motorvated by a hotrod 2.8L fully Ollie'd Mg case, twin-plugged EFI
but I've settled for a 'lightened '73 with hotrod twin-plugged, PMO carbed 3.2L & '75 915 box
you can get a bit more top-end hp on a 3.2L that is cammed up by going with RarelyL8's setup instead of SSIs - how often will you do that on the street?
The territory has been pretty fully explored, you just need a map and some ground-truth - so like the man said drive a few and escape the luxo-barge G50 Carreras
Maxhouse97 12-30-2020 11:13 AM
Thanks Paul - you are one of the few who have said I can get there with my 87. I do love my car, and may keep it regardless of this discussion, but I also am reluctant to dump another 10k into it doing a longhood conversion to get to that go-kart feeling and find out I failed. Guess it’s hard too as a lot of this is subjective. I do enjoy the conversation though.
Bill Verburg 12-30-2020 11:30 AM
The biggest difference that affects the dynamics is weight and where that weight is placed
compare a 1973 2.7 RS to a 1976 Carrera 3.0 to a 1987 Carrera 3.2
w/b is the same
o/a length goes from 4147mm to 4291mm(these #s are per factory, though I swear the US rubber bumper guards stick out further than the euro '76 versions)
the bumpers extend further and weigh much more, I had a '72S steel bumper spoiler on my '72 that weighed ~10# the '76 equivalent weighed over 25#, on both cars I replaced the oe w/ f/g parts @ ~6# & 9# respectively. The rear bumpers on the '72 were ~12# the '76 (remember a RoW) ~24#, no idea what an '87 rear is but I'm sure it's much more than the RoW76
the trans weights got from ~100# to ~122# to ~150#, varying by lsd or not by ~15#, but this weigh is concentrated near the CoM so doesn't affect dynamics much
engines will have a larger affect being further from CoM going from ~400# to ~410# to ~482#,biggest differences here are AC or no, air pump or not and them Mg or Al. and type of intake
the DIN curb weight goes from ~2365# to 2464#(though when I weighed mine it was 2401#) to 2750# So all the newer stuff adds up to ~385# more for the '87 vs '73, power to weigh goes from 11.3 to 11.5, not much change
the closer to the CoM any mass is the less leverage it has,
When I put f/g bumpers on the '72 it didn't appreciably change the feel, when I put f/g bumpers on the '76 the dynamics changed dramatically, back to back you could feel the car turning in more freely and w/ less rock on undulations. Hard to say if it was comparable to the '72 but I'd say at least very, very close
The other thing that changes feel is tires, On the '72 I went from 4x 185/70 on 6x15 to 215/235 on 7 & 8 x15, this made the steering much heavier until you got up to speed than not much difference though grip levels were much higher and over steer much reduced
the '76 came w/ 7 & 8x15 205/22,and was a rocket ship in its day, since i've used 7 & 8 x16 205/225, 8 &9x16 225/245 7 & 9 205/245 8 9.5 235/275 225/255, The larger wheels and tires on the latter chassis did pretty much the same as on the '72, The biggest thing I learned was to be very conscious of tire OD as it can have a huge effect on acceleration or perceived pep
So can you get the '87 to handle more like a '72 probably at least close but you will need to sacrifice at the very least bumpers, You can go further w/ f/g or c/f hood(f/r), remove sunroof go to lighter seats lighter carpet and not least if you stick w/ 7 & 8 x16 Fuchs change to 205/50 & 225/45 tires(these will liven the car noticeably over 205/55 & 225/50)
stock ride height of all of them is the same @108+/5mm & 12+/-5mm, all can benefit from judicious lowering
the early cars have 19/23mm t-bars the '87 19/25, a little stiffer t-bar does wonders for any of them as well, tweek w/ sways if you must the '87 already has some pretty hefty sways though
paul_howey 12-30-2020 11:40 AM
My pleasure! If you are ever in the Nashville area you are welcome to take mine for a spin.
I don't know if the finances will allow for it but I always think having at least one hotrod 911 in the garage is a good idea. This allows you to buy other stuff and just enjoy it for what it is and hop back in your other car when you want a little bit more.
I would honestly keep the 87' and just start a fund for the next car.
paul_howey 12-30-2020 11:41 AM
w/b is the same
Excellent info here!
RarlyL8 12-30-2020 02:58 PM
Backdating won't lower the weight any more than just putting fiberglass G-body bumpers on, much cheaper as well. If you follow that pattern with everything in the car and keep your stock parts then you can have the best of both worlds. Your Carrera has already had the interior modified so no big leap. I just sold an '87 and purchased a '73.5 for the same money. You can't trade even up for the same condition vehicle. The '87 was a really nice car, '73.5 needs work.
Another consideration is engine mods. With the 3.2L Carrera you have EFI, my tuned exhaust system with chip can get you from 217hp to 250hp. Add Sal's injection mods for even more. The 2.4L CIS may gain 15hp with tuned headers and set of Webers replacing the CIS. Not much else you can do without going into the engine or stand alone EFI/engine management. It's going to cost you a lot more to go faster in the early car which is why engine swaps are so popular.
BLACK3.2 12-30-2020 03:27 PM
I’m with the ruthless lightening crowd.
BLACK3.2 12-30-2020 04:07 PM
Remove the stereo, speakers and AC, remove the carpet and sound deadening, remove frunk carpet, spare tire, bumper reinforcements, add an alu hood and lighter rear deck, lightweight seats, RS door panels, single-mass flywheel, delete the sunroof, lightweight battery. Have no mercy.
I remember seeing a video a couple years ago of a chap who'd done a build like that. He took the interior down to bare metal and polished it. It was amazing, and it still retained the G body look.
I do think the G bodies will one day become just as desirable as the long hoods. Don't backdate!
OSC911 12-30-2020 05:25 PM
I have a ‘76 non sunroof coupe - no a/c, no power windows, no radio, no brake booster. It is a very fun car to drive - like go cart handling as previously stated. It is about as close to a long hood as I can get without the expense. I have had an SC and a 3.2 Carrera and I would rate the fun factor higher than both of these cars. In saying that, I never tried to shed weight from either but I am sure the less weight equals more fun. I am currently converting to a 3 litre with ITB so I hope I don’t spoil the feel of the car. I am fairly confident it won’t. My advice is to keep your ‘87 and loose some weight from it. You might not get the exact long hood experience but might get close.
Maxhouse97 12-30-2020 06:25 PM
Thanks for chiming in Bill, your opinion is very much appreciated. I like the fact that more people are weighing in with the thought that I can get close to if not replicate longhood handling with my 87. I would go backdate as I love the aesthetics of early cars. This is now making me reconsider selling my car.
targa72e 12-30-2020 10:48 PM
As a quick reference my 78 SC that I used as a street/track car weighed 2390 with half tank of gas. This was a non sunroof coupe, no AC, light weight seats, backdated exhaust,, etc. Had to bolt 100LBs in and run with 1/2 tank plus to meet weight for Clubrace. If you strip a late car down to the same features that were typical of early cars they are not that far apart weight wise. I also had a 72 at the same time 7/31 in the tranny made a big difference, especially on the street. I would not give up the ability to run larger (more modern tires avalible) wheels and aluminum case engine to go with early car. I think if you looked at minimalizing your currently car, Maybe add fiber glass bumpers, hood and deck lid you could get quite a bit lighter.
john
sundevil64 12-31-2020 03:45 AM
There is definitely a difference as all have stated. I seems to be a combination of things with weight being at the center of it. Driving my 73 targa in Texas hill country is so much fun because it is so light and responsive compared to my SC or my 78 930.
You don't want to go too light as that can have a negative affect towards what you are looking for. There seems to be a sweet spot at around 2200#-2400#. I got my 930 (no sunroof) down to 2560# and it was noticeably more responsive.
I think you can do this with a 74 car if you shave some weight where it counts, on the ends and unsprung weight. bumpers, decklids, and wheels. I would not suggest fb fenders on a street car for safety and rigidity reasons. I put 15" cookie cutters on my 85 Targa from 17" and huge difference in handling with regard to "tossability".
Keep those things in mind. Find a non-sunroof nb car and make adjustments as you go until you are happy.
Good luck on your journey.
paul_howey 12-31-2020 05:36 AM
john
^ This x100
I know you are getting hit with a lot of opinions in this thread but it all boils down to what YOU want and how YOU will use the car.
If you want a more tossable, fun car, no matter how lightweight you go, the wrong suspension and too wide of wheels will work against this goal. On the other hand, if you want to lean towards a more composed and capable street/track car, wider wheels and fully upgraded suspension will get you closer to that goal.
^ You can also decide you want to be somewhere in-between the two and find the right balance that fits your preference.
There are numerous littles spectrums like this when it comes to these cars and you just have to figure out where YOU fall within them and build the car accordingly.
You can accomplish whatever you want with proper know how, time, and budget. I personally think a lightweight later 911 with the desired aesthetics is the way to go. Values be damned. If you like the IB’s keep them. If you don’t, toss them.
I really don’t think the IB 911’s will ever achieve the values of pre-74’ cars (at least not within the next few decades) due to the high numbers produced and they are less prone to rust. There are just too many of them and the attrition rate is not very high.
On the other hand, a proper long hood conversion with tasteful mods always seems to fetch a premium in the various marketplaces and I don’t see that trend changing. So if you did end up doing the work and went to sell the car later, you would likely see most if not all your money back.
Maxhouse97 12-31-2020 09:31 AM
BTW my car currently sits at 2631 lbs.
paul_howey 12-31-2020 10:45 AM
You can probably get close to 2400lbs if you go lean on the interior (delete rear seats, RS door cards, delete audio, etc). SSI’s or headers with lightweight muffler (M&K mufflers are excellent). Backdate body with FB bumpers, delete heavy flag mirrors, delete rockers (weld up the holes and make custom torsion covers for G50 cars). I personally would get rid of the roll bar as well if this is mainly a street application as it adds weight. Much more likely to get rear ended by some texting teenager and end up with the bar to the back of the head then a roll over.
I personally would not recommend FG hood on a long hood conversion. They tend to warp after install due to the lack of support and it’s nearly impossible to get the gaps right. It’s one of the areas I sacrificed saving weight in order to have the front look correct.
I’m sure I’m forgetting a few things but those are some areas you can dump some significant weight quickly.
Maxhouse97 12-31-2020 11:07 AM
Ok great - I was also thinking of doing a sunroof delete while repainting the whole car.
87maniac 12-31-2020 11:18 AM
I drove '73.5, '74, '83SC, '87,
The 74 with 4x 185/70 tires on 6x15 felt -very close- to the '73.5.
It was light and very fun to drive. I believe the 74 is geared lower than later 911s.
I replaced the stock skinny wheels with 6x16/7x16 with low profile wide tire,
and that changed the feel of the car very much.
The nimble/light feelings were gone, replaced by heavier steering, more planted feel.
The difference between the 74 and the SC was a feeling of Too Much Weight.
the '87 is heavy like the SC, however, the torque of the 3.2 is wonderful.
The '87 has higher quality interior (than the '74), G50, and makes a nice touring car.
I imagine that a '74 lightweight would be a blast, careful choice of wheels/tires/
suspension will result in the early feel of a longhood.
kach22i 12-31-2020 11:34 AM
If you can have your cake and eat it to, the below special edition sounds like it.
Post #89
3.1 Liter SC-L
http://forums.pelicanparts.com/porsche-911-technical-forum/1072894-another-1979-restoration-but-one-special-5.html#post11066402
Point One
This forgotten 911 SC variant packs a punch.
https://www.excellence-mag.com/issues/180/articles/point-one
Sprenger’s team took the stock 930/03 engine seen in RoW SCs (930/09 for MY1980) and bored it from 95.0 to 97.0 mm, the same as the 3.3 Turbo motor. This yielded 3122 cc with the stock 70.4-mm stroke. The compression ratio was increased from 8.6:1 to 9.5:1, which necessitated the use of premium grade fuel (98 RON). An upgraded fuel distributor was employed, while pistons and cylinders were sourced from Mahle. To handle any additional cooling needs, a larger oil cooler — likely left over from the racing program and similar to the eventual 3.2’s unit — was mounted in the right front fender. Finally, a taller fifth gear of 0.759:1 (rather than 0.785:1) pushed top speed higher.
I think any year with a weight reduction regimen under it's belt is going to be above par.
However, only few will approach Lotus light.
WCN621 12-31-2020 06:38 PM
Maxhouse97, I can greatly appreciate where you’re coming from. With the desire for the responsiveness, handling and wanting those early 911 aesthetics. I am seriously considering a backdate on my 84’ as well. I’ve driven a number of 911’s, 68’ thru my 84’ but wanted the dependability, power and no rust of the 3.2. However, if I have had larger car budget, I would jump on a 914-6 (keeping the 911). I drove a street-legal 914-6 race car that my buddy has. Nothing has compared to that go-kart handling on steroids. It was fantastic. I never cared for the styling, but if you have the opportunity, drive a 914-6. If you like how it performs, you may overlook the styling and pine for one too. I think he’s going to be putting it on the market, so there will probably be one available.
dwelle 12-31-2020 06:58 PM
backdating will have very little effect on the handling and feel of the car.
losing weight will. one effects aesthetics, the other performance...
famoroso 01-01-2021 08:14 AM
Post #89
3.1 Liter SC-L
Point One
I've got my '87 M491 down to 2,856 from 2,950 (which includes taking ~20 pounds of reciprocating / rotating mass out of the power train in conjunction with a 3.4 rebuild). I'm shooting for sub 2,800 lbs eventually. The combination of a bit more power and a bit less weight feels pretty great though. However, with 225 & 245 Trofeo Rs, it is not tossable (more like planted AF). I may downsize my front wheel & tire and try less sticky 205s & 245s to see how it changes the feel (which, in conjunction with running Fuchs Evolution wheels will drop ~9.5 pounds of unsprung / rotating weight).
I have an 1,800 pound / 300 hp Lotus Elise one garage stall over. It's a great reminder that my 911 will never approach that type of HP / weight though, so I'm realistic with my goals.
One thing is certain. Weight is the enemy / light makes right. My '87 enjoys a foglight delete, stereo / speaker delete, Recaro Pole Positions, footwell blower (and blower control switch) delete, heater backdate / blower delete, M&K Active Exhaust pre-muffler + 1 in/out rear muffler and a rear bumperette delete + rear Euro crush tubes.
I'm kicking around an Antigravity Group 48 battery. It's a considerable (if costly for a battery) weight savings, but feels like a suboptimal location from a weight distribution perspective. I'd LOVE a sunroof delete, but absent some catastrophic need for a repaint, that ain't happening. I totally would have done the electric AC system to both drop a considerable amount of weight and shift a lot of the remaining weight forward, but my stock system blows 34 degree vent temps and I couldn't, in good conscience, rip that system out.
AFB24911S 01-01-2021 04:49 PM
Just another thought to add here: Porsche didn’t galvanize any of the long hood cars.
jac1976 01-01-2021 05:42 PM
Actually, galvanized steel was used on the floors and arches/inner panels starting in 1970 and increasingly was used through 1972-73 with the introduction of Thyssen steel.
mrrolleyes 01-01-2021 06:32 PM
This is my 76 narrow body 3.2 swapped non sunroof car. All steel w/ me in it, about 175. 3/4 tank of gas also.
No spare, small battery. No back seats but full carpet and leather, recaro PP seats. It’s pretty light w/ room to lose more if push came to shove.
http://forums.pelicanparts.com/uploa...1609554390.jpg
http://forums.pelicanparts.com/uploa...1609554493.jpg
Charles Freeborn 01-01-2021 06:56 PM
My '74. Dead stock, good tires, stiffer bars euro height. When the MFI 2.7 goes in this winter it'll be even more fun. I think the '74 is the best value out there. The 2.7 will need some mods and it's already at it's hp limit without spending $20k plus, but for overall value they can't be beat. Be sure to remove AC if it has it.
http://forums.pelicanparts.com/uploa...1609556048.jpg
Maxhouse97 01-02-2021 04:22 AM
Great responses, thanks for this. Here’s some more detail on my car from my valuing thread relative to weight savings I’ve already incorporated:
132,804 miles
- Steel synchros in trans rebuild by Brian Copan BMC & G at 119k miles, New clutch, KEP Lightweight aluminum pressure plate, new G50 clutch cross shaft kit
- Full 996 brake conversion with new front hubs to accommodate OE 996 front rotors, upgraded 23mm master cylinder
- Full Suspension rebuild: All new ER bushings, all new wheel bearing, new ball joints, bump steer kit, RSR 19mm lowered spindles, Tarett adjustable sway bar, Elephant racing custom valves shocks, drop links, turbo tie rods, full corner balance and aggressive street alignment
- Upgraded torsion bars 22/29 mm, hollow in rear
- Carrera front valence
- Bob Stratton duck tail
- Safety Devices roll cage
- J West Rennshift shifter and G50 coupler rubber bushing
- Steve Wong custom 93 octane chip
- Additional outlet stock exhaust
- Fabspeed cat delete (have stock cat)
- Removed a/c
- Heater backdate (have stock parts)
- K&N air filter and drilled air box
- Momo deep dish steering wheel
- TRE 917 style shift knob
- Recaro PP seats, custom leather and Alcantara covering, rennline seat belt anchors and sub strap
- Rennline triangular strut tower brace
- Rennline battery RE-location kit plus lightweight battery
- Aluminum foot rests
- H4 headlights with upgraded relays
- Fikse/Zuffenhaus forged wheels 17”
- Wevo engine mounts
- Magnecor plug wires
- Webcam 20/21 camshafts
- Recent refresh (piston rings, steel head studs, etc) at 131k. miles. Stuttgart Services, Louisville KY. New engine sound pad. Rebuilt valve guides at 88k.
- Euro bumperettes, lightweight Euro bumper shocks (minus bumper shock tow hook), Bosch euro taillights
- Custom interior refinish with carpet/sound insulation
- 996 aluminum spare tire
After this thread I’m really thinking of going down to 15” or 16” wheels with narrower tires. Right now I’m on 225/245 17s. Then you start looking at a backdate for both aesthetic and weight reasons.
http://forums.pelicanparts.com/uploa...1609590085.jpg
ted 01-02-2021 09:31 AM
The best go kart feeling my 69 911 provided was with some 15 inch rims and short 23.5 inch tall cantilever slicks.
Taller tires and larger diameter wheels made it feel heavy like a passenger was in the car.
Get an extra set of cheap rims with some short tires and it will feel more like a go kart.
Go kart handling to me means you are on top of the tire and can pitch and catch the car easily.
That requires driver training and experience, without those skills removing weight is pointless.
http://forums.pelicanparts.com/uploa...1609608338.jpg
My all stock 86 turbo look handles great and takes as much skill to maintain momentum.
Maintaining momentum is important with these heavy and underpowered low torque old cars.
shawn908 01-02-2021 01:45 PM
Agree weight loss makes a difference - and wheel size. My 74 has been on a weight loss regimen, now @2322#s (sans driver, spare, ac etc) and 1/2 tank fuel. With cookie cutter 7x15s all around and 235 width R888s it seems go-kart like and is very enjoyable to drive on country roads with a stock 3.2. Tire pressure makes a noticeable difference to how it handles, but it takes corners flat and has predictable handling (sticks to road) The mods/suspension of your listed setup is similar to my car (some of what's on your list is on my to do list...) - except the wheels/tires. With 15s and balanced/aligned/camber setup etc - more "go-kart" handling could be close and directly assessed before mods to body. One idea: do a few autocross runs w/ 17s then between runs swap to 15s w/R888 tires (or other performance spec tire).
Bill Verburg 01-02-2021 02:41 PM
132,804 miles
- Removed a/c
Nice car!
Those wheels are some of the best you can buy, only change there is to maybe use 215/45 fronts. The torque cost w/ 215/45//245/40 x17 on those wheels is already lower than the torque cost on any 7 & 8 or 7 & 9 or 8 & 9 x16 Fuchs setup except 7 & 8 x16 Fuchs w/ 205/50 & 225/45 tires, In other word the car will go and stop quicker w/ what you have unless you go to 15s which may be problematic w/ your brakes, However you also give up lateral grip going to any 16 or 15 set up, except w/ custom 8 & 9.5 x15 wheels w/ 225/45 and 245/40 tires. Though tire line choice also influences this.
I have 8 & 9.5 x17 225/45 & 255/40 on my 3.6 C3 and though the liveliness of shorter tires is appreciated I'd find it very hard to give up the grip.
You need to trim mass from both ends, the front being more important than the back because of it's longer lever arm.
As a test remove the spare and drive that way for a while to at least partially see the effects
