Upgrade to 175amp alternator generator light on. How do I fix it?
Hi guys,
Just upgraded my alternator to a 175amp to as part of my Electric AC install and my generator light stays on. I've heard that I need a voltage regulator. My car is a '74 with an '83 3.2 SS motor w/ MSD ignition and the '83 wiring harness. From my understanding the '83 harness didn't have a separate wire to install a voltage regulator as it was part of the Jetronic system. Does anyone know how to fix this problem? How to do it and what type of regulator I would need to install. Of course I could disconnect the light but I'd prefer to have it operational. Thank you, Joe |
John W
Joe, do some searches on the forum. As I recall you need to add a resistor to fix it. It’s explained here somewhere.
I'll try to search some more... I've searched a handful of times but didn't find anything, I'll trying searching resistor to see if I can dig it up. Thank you for the tip
ROW '78 911 Targa
ROW '78 911 Targa
Part is NLA from Porsche, but I could make one up for you.
PM or email me. Installed on a lamp holder: ![]() What I have made for others:
Thank Dennis. This would be great. I sent you a PM.
This is what an original one looks like
Lorne M.
83 SC |
To be clear, our 175A alternator has an internal voltage regulator. On cars that previously had an external regulator, the Porsche Service Bulletin procedure (posted by Dennis / timmy2) must be carried out. This is a wiring change but also may require the resistor mod posted above. We also reprint the bulletin in the back of our installation manual on our website.
www.classicretrofit.com |
