-   -   idle after ssi upgrade (http://forums.pelicanparts.com/porsche-911-technical-forum/108246-idle-after-ssi-upgrade.html)
MAD4PORSCHE 04-27-2003 05:32 PM
Just got done with an SSI upgrade on my 81SC. I knew my engine would breath easier, but I did not expect my idle to jumped from 1000rpm to 1800rpm after the upgrade. Is this normal? I also removed the oxygen sensor, but I don't think it was working anyway. Just wanted get some feedback before I started adjusting things.
Revs quicker and sounds sweet!!!!!!
http://www.pelicanparts.com/support/smileys/wat6.gif
Joeaksa 04-27-2003 07:14 PM
Sounds like you might have a vacuum leak that occured after the installation. Put the SSI's on my car and nothing changed but then I have the DME system on my car.
Joe
Vipergrün 04-27-2003 07:30 PM
If I recall correctly, the O2 sensor will lean out the motor. So, in theory, with it removed, the motor would be running richer now, which could cause the increase in idle. Have you tried to either turn the idle adjustment screw, or adjust the mixture? Just a thought....
RoninLB 04-27-2003 09:00 PM
Hey MAD... what size plug did you use on the SSI when you removed the sensor? .........Ron
osidak 04-27-2003 09:11 PM
Don't have an O2 sensor on my SSI's but I know for a fact that a spark plug will screw right into the o2 bung on my old cat.
RoninLB 04-27-2003 09:18 PM
thanks Doc.. that's one lead..
I got the SC SSI w/ the gasket protector because my heads are set up for it.........Ron
osidak 04-27-2003 09:32 PM
No problem Ronin. Just went out to the garage to look to see what plug I used.
It is Autolite 45. Wanted to buy the cheapest thing I could to plug the hole and at <$1.00 it fit the bill.
Anyone want to buy a good cat? $50 plus shipping
cab83_750 04-28-2003 08:40 AM
How much would you think the shipping would be?
