Tachometer stopped working
My tachometer stopped working ,not sure if it's the tachometer or wiring. Any idea how to check?
You really need a tach tester or possibly a signal generator to test your tach. What year is the car?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Anyone nearby you can borrow another tach from? Some multimeters have a frequency (Hz) setting that you could use to test the tach signal to confirm it's getting to the tach.
I'd be happy to test it for you but unless you are in Socal it would require sending it back and forth
