9volt DC output under dash
Found a 9v DC power outlet under the dash on my '83 911SC? What is this for?
Photos?
It was not something that came from the factory. Likely some aftermarket device like a GPS or some other gizmo.
Thanks! I appreciate the input and that makes sense.
believe the original generation passport radar detectors required 9v power and came with a small transformer that could be used for a semi-permanent installation
Valentine 1 as well I believe
There has to be a small transformer somewhere to step down the voltage. What’s the box look like? |
Could also be a 'memory saver' for when you have to remove the battery ?
| All times are GMT -8. The time now is 11:10 PM. |
