Question 9volt DC output under dash
Found a 9v DC power outlet under the dash on my '83 911SC? What is this for?
Old 01-07-2021, 10:08 AM
Photos?
Old 01-07-2021, 10:21 AM
It was not something that came from the factory. Likely some aftermarket device like a GPS or some other gizmo.
Old 01-07-2021, 11:51 AM
Thanks! I appreciate the input and that makes sense.
Old 01-07-2021, 12:54 PM
believe the original generation passport radar detectors required 9v power and came with a small transformer that could be used for a semi-permanent installation
Old 01-07-2021, 01:02 PM
Been here a while
Valentine 1 as well I believe
There has to be a small transformer somewhere to step down the voltage. What’s the box look like?
looking for 1972 911t motor XR584, S/N 6121622
Old 01-07-2021, 01:29 PM
cycling has-been
bkreigsr's Avatar
Could also be a 'memory saver' for when you have to remove the battery ?
Old 01-08-2021, 12:15 PM
Racer
winders's Avatar
No. The original Valentine 1 required 11.0-16.0 volts DC. The new Valentine 1 Gen2 requires 6.0-35.0 Volts DC.
Scott Winders
PCA GT3 #3
2021 & 2022 PCA GT3 National Champion
2021 & 2022 PCA West Coast Series GT3 Champion
Old 01-08-2021, 12:28 PM
Wow, so it will work in a 6 volt car or a 24 volt car or up to 35 volts? Amazing range of voltage.
Old 01-08-2021, 02:30 PM
