-   -   Engine conked out (http://forums.pelicanparts.com/porsche-911-technical-forum/1082938-engine-conked-out.html)
hook682 01-10-2021 07:13 AM
Engine conked out
Hey Guys, so I was warming the 83SC in the garage this morning. After about 10 minutes the engine just died. I tried to restart it and it just cranked over real fast, that was it. Got any ideas what to look at first? Thanks.
proporsche 01-10-2021 07:22 AM
check your fuse number 6 from the windshield--you should have fuse box cover with fuse index on it--then report
Ivan
i assume you know where fuses are?
hook682 01-10-2021 09:04 AM
Ivan, that was it, the fuse fell apart when I touched it. Do you know the value of that and what it is for?
Flat6pac 01-10-2021 09:33 AM
It’s fuel pump fuse
The value might be inside the cover, it is in the manuals.
Bruce
proporsche 01-10-2021 09:46 AM
fuse for fuel pump is usually blue 30A....also check the others .If they are plastic look o-line cor ceramic fuses ,thay last longer and can take the heat...
Ivan
hook682 01-10-2021 09:50 AM
Thanks guys, fuses ordered.
LIRS6 01-10-2021 02:08 PM
Did you find ceramic fuses, if so where? Our host is out of stock.
Jason
mikesarge 01-10-2021 02:19 PM
Jason
2nd.
Also, beware cheap fuses: they’ll melt and leave you stranded.
hook682 01-10-2021 02:34 PM
I ordered thru pelican, I guess they are plastic
pmax 01-10-2021 02:55 PM
Fuel pump on its way out ?
hook682 01-10-2021 03:37 PM
What’s the normal current flow? I can put a clamp on on it,
proporsche 01-12-2021 10:25 AM
hook..if would like i have plenty of ceramic fuses...you can have some for free,just have to pay for postage..
In case you will not be happy with the plastic.Or cannot find ceramic ..
Ivan
Solamar 01-12-2021 01:30 PM
I believe the German Flosser brand torpedo fuses are known to be high quality. They have the ceramic body. Inexpensive and readily available on Ebay, just buy from a reputable seller.
OldSpool87 01-12-2021 06:44 PM
You can try Memotronics. They have ceramics except for 8amp (white) which are impossible to find in my experience.
Brown747 01-12-2021 08:21 PM
Time to upgrade to modern blade fuses. Host has the kit.
https://www.pelicanparts.com/More_Info/RFZ7483.htm?pn=RFZ-74-83&bt=Y&fs=0&SVSVSI=790
I did it to my car last summer. Took an afternoon. Recommended
Thor
http://forums.pelicanparts.com/uploa...1610514828.jpg
http://forums.pelicanparts.com/uploa...1610515112.jpg
hook682 01-13-2021 11:38 AM
Ivan
Thanks Ivan
proporsche 01-13-2021 01:02 PM
Originally Posted by hook682 (Post 11180570)
Thanks Ivan
no problem .if you need, you know where to find me
Ivan
DonNewton 01-13-2021 01:42 PM
Thor
On my to-do list for my SC. Just did my 914 race car as a break-in. . .
LIRS6 01-19-2021 09:37 AM
I just received plastic 16 amp + 8 amp fuses, whereas product description was ceramic (not our host).
Send 'em back, or just live with them?
Jason
MBAtarga 01-19-2021 10:14 AM
I'd say plastic composite shouldn't impact performance.
