Engine conked out
Hey Guys, so I was warming the 83SC in the garage this morning. After about 10 minutes the engine just died. I tried to restart it and it just cranked over real fast, that was it. Got any ideas what to look at first? Thanks.
check your fuse number 6 from the windshield--you should have fuse box cover with fuse index on it--then report
Ivan i assume you know where fuses are?
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Ivan, that was it, the fuse fell apart when I touched it. Do you know the value of that and what it is for?
It’s fuel pump fuse
The value might be inside the cover, it is in the manuals. Bruce |
fuse for fuel pump is usually blue 30A....also check the others .If they are plastic look o-line cor ceramic fuses ,thay last longer and can take the heat...
Ivan
Thanks guys, fuses ordered.
Did you find ceramic fuses, if so where? Our host is out of stock.
Thanks Jason
'79 911SC Targa |
Slow old car
Also, beware cheap fuses: they’ll melt and leave you stranded.
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
I ordered thru pelican, I guess they are plastic
Still here
Fuel pump on its way out ?
What’s the normal current flow? I can put a clamp on on it,
hook..if would like i have plenty of ceramic fuses...you can have some for free,just have to pay for postage..
In case you will not be happy with the plastic.Or cannot find ceramic .. Ivan
I believe the German Flosser brand torpedo fuses are known to be high quality. They have the ceramic body. Inexpensive and readily available on Ebay, just buy from a reputable seller.
1978 SC Targa |
You can try Memotronics. They have ceramics except for 8amp (white) which are impossible to find in my experience.
Time to upgrade to modern blade fuses. Host has the kit.
https://www.pelicanparts.com/More_Info/RFZ7483.htm?pn=RFZ-74-83&bt=Y&fs=0&SVSVSI=790 I did it to my car last summer. Took an afternoon. Recommended Thor ![]()
1978 SC coupe #1834 |
no problem .if you need, you know where to find me
Ivan
Don Newton “People sleep peaceably in their beds at night,” George Orwell wrote, “only because rough men stand ready to do violence on their behalf.” "I gave up visiting my psychoanalyst because he was meddling too much in my private life." Tennessee Williams |
I just received plastic 16 amp + 8 amp fuses, whereas product description was ceramic (not our host).
Send 'em back, or just live with them? Jason
'79 911SC Targa |
I'd say plastic composite shouldn't impact performance.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
