MFI stack rebuild
I’m the second owner of a 71 911E and ever since I can remember the valves at the bottom of the MFI stacks have always been loose and go click click click. I am now retired and have time to tinker with it myself. Where would be the best source to get a manual on how to rebuild these?
Thanks, Mark |
These parts are precision and not trivial. Unless you have the tools (machine shop) and experience, I would punt to one of the expert vendors that does this kind of work.
You'll need the right bushings, everything has to be lined up just so, etc, etc. If you like to tinker, have at it though. That's the fun of these cars for a lot of people. Me, I'm pretty mechanical, and wouldn't touch the components of the MFI system with a 10 ft pole; but that's just me.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS Last edited by skinnerd; 01-17-2021 at 06:55 PM.. |
Here's my 2.7 MFI engine being rebuilt recently by the experts.
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS |
Thank you, I will take your suggestion and find a machine shop
Matt Blast at I think Eurometrics
Behind the Sun
Eurometrix in Massachusetts
That's all Matt does |
Yeah....your typical machine shop isn't going to be able to do this justice.
Eurometrix.ws is definitely a good call. I've used them in the past. Solid. For the above (and below) engine build, I used Burnham Performance out of Camarillo, CA and they were top notch. You'd talk to Aaron there I believe. They are works of art: ![]() ![]()
"Are you out of your Vulcan mind?" Doug 2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS Last edited by skinnerd; 01-18-2021 at 10:20 PM.. |
+1 for Aaron Burnham
You also can't go wrong with Henry Schmidt at Supertec Performance.
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
