bcgreen's Avatar
Is there a difference if the COA is produced in the US or
in Germany, in regards to a Porsche produced for the German market (ROW)?
66 Shelby Hertz Renta-Racer
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 01-20-2021, 06:49 AM
djpateman's Avatar
The CoA is now obsolete, and replaced with the PPS and CTC. The PPS will often have reduced information, and you have to supply the engine & trans #'s. The CTC is an inspection in a authorized facility, and will verify what is present; but at 4 times the price. Each national distributor has a slightly different format and level of detail.
I offer an unofficial Report with greater level of detail.
Keeper of 356, 911, 912 & 914 databases; source for Kardex and CoA-type reports; email for info
Researching 356, 911, 912 & 914 Paint codes, Engine #'s and Transmission #'s
Addicted since 1975
Old 01-20-2021, 07:27 AM
bcgreen's Avatar
Sorry but I am not current with the acronyms.
68 Shelby 500KR
78 Ferrrari 308
16 Macan S
11 Speedster
Old 01-20-2021, 07:30 AM
racer's Avatar
https://www.porsche.com/usa/accessoriesandservices/classic/technicalcertificate/
KARDEX - Pre 1970, the actual Porsche build sheet record.
COA - Certificate of Authenticity
CTC - Classic Technical Certificate
PPS - Porsche Production Specifications - this form specifically mentions North American cars only (US and Canada)
The end of the COAs imho got compromised because they no longer provided factory information for some items. Instead, they simply wrote the information you provided. Sounds like the successor PPS does the same thing.. It writes up what YOU present. Not sure if it gives an asterisk to denote something like *not original
I am not sure how Porsche NA handles "grey market" or ROW car information. I presume they have access to a global database, but in real time (1980s primarily) the German companies practically banned ROW cars from service at US dealerships.
Past:
2000 Boxster 2.7, 1987 944, 1987 924S
1978 911SC, 1976 914 2.0, 1970 914 w/2056
Old 01-20-2021, 12:22 PM
RETIRED
Joe Bob's Avatar
CW - Concour Weenie
Proper and Correct - CW with a pocket protector
Qtip - Something used to clean anything but your ears
Valve Stem - Something aligned with the bottom of your hubcap crest
Feel free to add to the above.
Old 01-20-2021, 12:28 PM
Mark Salvetti's Avatar
I think it used to be you gave Porsche the VIN and they sent you the COA with the engine and transmission numbers. For valuable cars, that meant it would be possible to forge the engine and gearbox if the original wasn't there.
So then there was a period where you gave them your VIN, engine, and transmission numbers, and if they all matched their records, they sent you the COA confirming the numbers.
Now the only way to get the engine and transmission numbers verified is to spend $500 for the CTC and have a Porsche dealer inspect the car and confirm the numbers. I think you can get a CTC for ROW cars. Here is a sample: https://www.porsche.com/all/media/flash/classic/certificate/en/6/
The PPS costs $100, but no longer has the engine and transmission numbers.
Mark
1979 911SC Targa
Old 01-20-2021, 02:55 PM
