-   -   First Engine Drop (http://forums.pelicanparts.com/porsche-911-technical-forum/1083579-first-engine-drop.html)
Funracer 12-03-2021 06:38 PM
Might get another look at it tomorrow but have other plans for later in the day.
Gooo Georgia!
DaytonaCoupe66 12-04-2021 04:02 AM
If the bolts won't go in all of the way, and the wheels are now locked up, you may be using the wrong length bolt, as in too long.
Funracer 12-04-2021 05:20 AM
Other side is already done with same size bolts. No issues.
DaytonaCoupe66 12-05-2021 05:28 AM
Okie; based on your description in post #157 I still think you'd be well advised to measure the bolts length as it sounds like the ends are landing against your trailing arm, or maybe the output flange of your tansaxle. What comes out of an old car isn't always what the factory had put in originally. Good luck!
Funracer 12-05-2021 06:38 AM
I am using moon plates on the wheel side and have slightly longer bolts for that side. Since I will be removing the stub axle now I will take a good look at that. If the shorter bolts will work with the moon plates I will use them . I have plenty of both lengths.
Funracer 12-06-2021 06:48 PM
Got it all sorted and back together today. Pulling the stub axle was not difficult. The broken piece came right out.http://forums.pelicanparts.com/uploa...1638848831.jpg
http://forums.pelicanparts.com/uploa...1638848871.jpg
Funracer 12-06-2021 06:55 PM
Torqued up the drive axles today and took her for the first drive in 11 months. Engine starts immediately and idles smoothly. A couple of small issues to adjust but overall really happy. No leaks so far. Now to get that AFR gauge working….
Quasimoto 12-06-2021 11:30 PM
Congratulations, that has to feel pretty good!
Funracer 12-07-2021 07:29 AM
Yes it does. Probably my biggest project to date given I knew nothing about Porsches three years ago.
So far loving my new M&K 27ST 2 in 1 out. Only put about 5 miles on it so far. After I drive it for a month I will do a separate review. It’s definitely not too loud which is what I was looking for.
Now to clean up the mess I have left in my garage.
Once I get the AFR set up and the car tuned I’m going to drive it for awhile, new tires, then think about a suspension refresh. Sway bars, shocks and new rubber bits.
Another box to check is to drive it to one of the big Pcar gathering. Porsche Parade, Luftkegult or the like.
All in good fun.
17yrsWith930 03-04-2022 11:43 AM
Great accomplishment
Great job Funracer !
Congrats.
I read thru most of this thread and there were several things that were good for me to hear.
I pulled my Carrera engine and trans in early winter (northern hemisphere) and am preparing for the re-install. This is not my first air cooled, and I've always had one around since 1986 ..... But, this is the first time I've pulled an engine.
Thanks for the thread !!
Mark
