-   -   Making my own Headers!!! (http://forums.pelicanparts.com/porsche-911-technical-forum/108371-making-my-own-headers.html)
DMX 04-28-2003 10:27 AM
I AM BUILDING MY OWN HEADERS LIKE THE PICTURE BELOW....
JUST NEED ONE QUESTION ANSWERED..... WHAT WIDTH OF
PIPING SHOULD I USE FOR THE 2 PIPES THAT CONNECT TO THE
MUFFLER FROM EACH HEADER.... I AM THINKING 3 INCH PIPES... I
WANT A THROATY SOUND, NOT A HIGH PITCH SOUND.... MAYBE I
SHOULD USE 4 INCH PIPES.... ANY ANSWERS.... THIS IS NOT MY
AREA.....
THANKS...
:D
http://www.pelicanparts.com/catalog/...r_3muffler.jpg
ChrisBennet 04-28-2003 10:39 AM
You need to do more homework before you start. Bigger pipes = lower velocity = no low end torque.
-Chris
DMX 04-28-2003 10:46 AM
I got the original older style pieces that fit right to my engine.... I am
just custimizing the pipe on each side that goes to the muffler... I think
either a 2 1/2 inch or 3 inch would be best for performance.... but not
too sure...
emcon5 04-28-2003 10:51 AM
What car, what engine?
Tom
DMX 04-28-2003 10:53 AM
2.7L '75 911.. ... I have a stainless muffler with an empty cat right
now and my car runs really strong... I am hoping to gain some
horsepower by adding a header system with dual inlets to the
muffler.. .. ...
ChrisBennet 04-28-2003 11:09 AM
If you want to add power, copy/study SSI's. SSI's themselves are an improved version of the factory '74 headers. They are a very good design - superior to the system you have pictured even.
-Chris
DMX 04-28-2003 11:17 AM
Do you think I will notice a big difference from changing to dual
inlets instead of the single inlet that wraps around the side of my
motor?
ChrisBennet 04-28-2003 11:24 AM
motor?
I know it makes a noticeable difference on 3.0 motors. Fabspeed contends that a Euro "premuffler" makes as much HP as SSI's on a 3.2 I think. Now the SSI's are a little small for a 3.2 so it's not really comparing apples to apples. I too wonder how a gutted cat compares to SSI's in your application.
-Chris
TerryBPP 04-28-2003 11:32 AM
When I sent my headers out to get jet-hotted I used a stock setup and I could definetly tell the difference the duals made. I use a headers, not cats, 2 dansks mufflers, and to 2 1/4" outs.
DMX 04-28-2003 11:40 AM
Hey Chris I am wondering the same.... I hope it's worth it... I may just
put the old style headers on and fabricate another inlet to my stainless
muffler... I hope it runs stronger... .. ... I think I will gain torque..
Terry.....
Did you notice a big difference in torque.... I heard that I would have
more torque in every gear.... Is this true.... and it will cost me basically
nothing to convert over my exhaust so I think it will be worth it...
DMX 04-28-2003 11:43 AM
Oh and by the way... Has anyone heard of by design.... That is my
stainless muffler.... is it good or just some aftermarket junk.... Sounds
good when the car is on so thats what counts to me.... HAHAHA
Kemo 04-28-2003 11:47 AM
Be sure and post some pics...this looks like a worthy project. Im sure that porsche put alot of time in developing the tuned headers up to 74...then SSI picked it up from there, not to mention Bruce Anderson's view of the early style HEs. So as Chris Bennet pointed out, you would be on the right track by copying someone that has already made a great product
...if anyone has dimensions on the stock early style HE's or 2.7SSI's, that would most likely be the right diameter.
Kemo 04-28-2003 11:50 AM
you could build in an 'X' pipe of some sort...that would be cool. :)
DMX 04-28-2003 12:31 PM
Anyone have a picture of the old headers.... I need to see what
they look like..... I cannot seem to find a picture of them....
Kemo 04-28-2003 12:54 PM
http://www.stuttgart.co.uk/ssi.html
this shows a pic...UK site tho.
jluetjen 04-28-2003 01:02 PM
I have a set (sans heater boxes) in the garage which I just measured. Curiously the primaries are 1 3/8 (id) and the secondaries are 1 3/4 inches. I say curiously because everything that I ever read said that the early systems had 1 1/2 inch primaries. Hmmm. Go figure!:confused:
TerryBPP 04-28-2003 01:35 PM
There was definetly a increase in power.
David 04-28-2003 05:09 PM
I would do some serious calculations on all your diameters and lengths before starting, even if you copy someone else's design. If you make it out of stainless you will probably spend several hundred dollars, time spent in design would be well worth it. Here's a good site for material and tips: http://www.burnsstainless.com
