DMX DMX is offline
DMX's Avatar
Thumbs up Making my own Headers!!!
I AM BUILDING MY OWN HEADERS LIKE THE PICTURE BELOW....
JUST NEED ONE QUESTION ANSWERED..... WHAT WIDTH OF
PIPING SHOULD I USE FOR THE 2 PIPES THAT CONNECT TO THE
MUFFLER FROM EACH HEADER.... I AM THINKING 3 INCH PIPES... I
WANT A THROATY SOUND, NOT A HIGH PITCH SOUND.... MAYBE I
SHOULD USE 4 INCH PIPES.... ANY ANSWERS.... THIS IS NOT MY
AREA.....
THANKS...
Old 04-28-2003, 10:27 AM
Irrationally exuberant
ChrisBennet's Avatar
You need to do more homework before you start. Bigger pipes = lower velocity = no low end torque.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 04-28-2003, 10:39 AM
DMX DMX is offline
DMX's Avatar
I got the original older style pieces that fit right to my engine.... I am
just custimizing the pipe on each side that goes to the muffler... I think
either a 2 1/2 inch or 3 inch would be best for performance.... but not
too sure...
Old 04-28-2003, 10:46 AM
Hilbilly Deluxe
emcon5's Avatar
What car, what engine?
Tom
82 911SC Coupe
GTI Cup #43
Old 04-28-2003, 10:51 AM
DMX DMX is offline
DMX's Avatar
2.7L '75 911.. ... I have a stainless muffler with an empty cat right
now and my car runs really strong... I am hoping to gain some
horsepower by adding a header system with dual inlets to the
muffler.. .. ...
Old 04-28-2003, 10:53 AM
If you want to add power, copy/study SSI's. SSI's themselves are an improved version of the factory '74 headers. They are a very good design - superior to the system you have pictured even.
-Chris
Old 04-28-2003, 11:09 AM
DMX DMX is offline
DMX's Avatar
Do you think I will notice a big difference from changing to dual
inlets instead of the single inlet that wraps around the side of my
motor?
Old 04-28-2003, 11:17 AM
motor?
I know it makes a noticeable difference on 3.0 motors. Fabspeed contends that a Euro "premuffler" makes as much HP as SSI's on a 3.2 I think. Now the SSI's are a little small for a 3.2 so it's not really comparing apples to apples. I too wonder how a gutted cat compares to SSI's in your application.
-Chris
Old 04-28-2003, 11:24 AM
TerryBPP's Avatar
When I sent my headers out to get jet-hotted I used a stock setup and I could definetly tell the difference the duals made. I use a headers, not cats, 2 dansks mufflers, and to 2 1/4" outs.
Old 04-28-2003, 11:32 AM
DMX DMX is offline
DMX's Avatar
Hey Chris I am wondering the same.... I hope it's worth it... I may just
put the old style headers on and fabricate another inlet to my stainless
muffler... I hope it runs stronger... .. ... I think I will gain torque..
Terry.....
Did you notice a big difference in torque.... I heard that I would have
more torque in every gear.... Is this true.... and it will cost me basically
nothing to convert over my exhaust so I think it will be worth it...
Old 04-28-2003, 11:40 AM
DMX DMX is offline
DMX's Avatar
Oh and by the way... Has anyone heard of by design.... That is my
stainless muffler.... is it good or just some aftermarket junk.... Sounds
good when the car is on so thats what counts to me.... HAHAHA
Old 04-28-2003, 11:43 AM
Black and Blue
Kemo's Avatar
Send a message via Yahoo to Kemo
Be sure and post some pics...this looks like a worthy project. Im sure that porsche put alot of time in developing the tuned headers up to 74...then SSI picked it up from there, not to mention Bruce Anderson's view of the early style HEs. So as Chris Bennet pointed out, you would be on the right track by copying someone that has already made a great product
...if anyone has dimensions on the stock early style HE's or 2.7SSI's, that would most likely be the right diameter.
Kemo
1978 911 SC Non-Sunroof Coupe, two tone Primer Black and SWEPCO Blue, Currently serving as a Track Whore
1981 911 SC Sunroof Coupe, Pacific Blue Project, Future Daily Driver
Old 04-28-2003, 11:47 AM
Black and Blue
Kemo's Avatar
you could build in an 'X' pipe of some sort...that would be cool.
Kemo
Old 04-28-2003, 11:50 AM
DMX DMX is offline
DMX's Avatar
Anyone have a picture of the old headers.... I need to see what
they look like..... I cannot seem to find a picture of them....
Old 04-28-2003, 12:31 PM
Black and Blue
Kemo's Avatar
http://www.stuttgart.co.uk/ssi.html
this shows a pic...UK site tho.
Kemo
Old 04-28-2003, 12:54 PM
jluetjen's Avatar
I have a set (sans heater boxes) in the garage which I just measured. Curiously the primaries are 1 3/8 (id) and the secondaries are 1 3/4 inches. I say curiously because everything that I ever read said that the early systems had 1 1/2 inch primaries. Hmmm. Go figure!
John
'69 911E
"It's a poor craftsman who blames their tools" -- Unknown
"Any suspension -- no matter how poorly designed -- can be made to work reasonably well if you just stop it from moving." -- Colin Chapman
Old 04-28-2003, 01:02 PM
TerryBPP's Avatar
There was definetly a increase in power.
Old 04-28-2003, 01:35 PM
David's Avatar
I would do some serious calculations on all your diameters and lengths before starting, even if you copy someone else's design. If you make it out of stainless you will probably spend several hundred dollars, time spent in design would be well worth it. Here's a good site for material and tips: http://www.burnsstainless.com
Old 04-28-2003, 05:09 PM
