AirCooledExcellence's Avatar
Unhappy My New Muffler - Don't Fit!!
Hi All,
I Picked up this muffler from a swap meet yesterday, it's a Cargraphic (Model Car4) and very nice quality bit of kit:
The vendor assured me that it would fit my SSI shod SC. Tried a test fit this afternoon and it turns out that the tailpipes need to be about 4cm lower to clear the rear bumper (I've removed the rear valance). Here are some pics:
I assuming that it's actually a special exhaust designed to be used in conjuction with a Cargraphic body kit.
I'm guessing that it wouldn't be a huge job to get a muffler shop to remove the outlets and angle them down a bit to get the clearance I need? I was also thinking of getting them to extend each outlet outwards about an inch or so to center them properly.
What do you guys think, is this feasable? Also, what do you think of the look? I think it looks badass!
Cheers
PS: Note to Jakes, Brian, Nick etc - Please dont laugh!!
1984 Carrera - 3.6 Conversion, 326bhp, 1020kg - SOLD
1987 930 - SOLD
1983 911 SC Targa - SOLD
http://forums.pelicanparts.com/impactbumpers.com - Classic 911's and nothing else
Old 04-27-2003, 11:03 AM
Friend of Warren
Yep, a muffler shop should be able to angle the outlets down, but will that give you the clearance without actually moving the complete outlet holes lower on the muffler?
Kurt V
Old 04-27-2003, 11:20 AM
drag racing the short bus
dd74's Avatar
Tim: I'm not sure what you mean? They look like they clear fine. The right side dips a little bit, but that seems like a "fit" problem. Is that what you mean? I'm not sure.
They look good otherwise.
The Terror of Tiny Town
Old 04-27-2003, 11:23 AM
Guys, the muffler is not bolted up in the pictures, it's just jacked up under the car, I need it to go up another 3-4CM before I can bolt it up to my SSI's
Cheers
1987 930 - SOLD
Old 04-27-2003, 11:31 AM
Senior Member
Jdub's Avatar
Custom muffler shop can do this for you (they can do some amazing things). If you don't have to have those tips running straight out then as you say you are in good shape to have the shop put in nicely bent items that will not block flow.
And I guess I have to say you ought to remove those tips anyways in favor of flat black tips. What you have there does not fit at all with the black trim on your car and is a bit poseur for my tastes anyways (what the heck do I know?).
John
'78 Targa in Minerva Blue
Old 04-27-2003, 12:25 PM
It'll be legen-waitforit
stealthn's Avatar
Tim,
Meaty!, I'd go to a muff shop with a case of beer and see if one of the guys will cut them and add a downward piece....
Amber lubricant...
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 04-27-2003, 12:26 PM
Mikkel
Guest
Posts: n/a
Does the muffler have any identification on it e.g. numbers stamped into the metal or similar? It's probably for an early car. What size are the tailpipes? They look like 100mm/4 inches?
I'm in the process of finding the right muffler for my new set of SSI's. Today I drove a 3,2 with SSI's and an early stock 1 out muffler in regular steel with a custom tail pipe. I'm glad I did. Awesome sound. Lovely deep, but with an aggressive raspy metal like sound to it. This muffler didn't fit on a 3,2 either. At least not until the custom tail pipe was installed.
Old 04-27-2003, 12:40 PM
John - Remove the tips, you must be joking!!!
Mikkel, it's a Cargraphic muffler and yes they are 4 inch outlets. It has an ID plate tacked on the underside just has 'Car 4' etched on it. I'm convinced that this must be a custom exhaust that was meant to fit with a Cargraphic body kit.
I'll post some sound files when I eventually get it bolted up
Cheers
1987 930 - SOLD
Old 04-27-2003, 01:03 PM
Administrator
Jack Olsen's Avatar
If you're asking for opinions, here's mine: those things are too big.
If it were me, I'd have the muffler shop install smaller (and possibly even black) tips.
Old 04-27-2003, 01:18 PM
Automotive Monomaniac
Emission's Avatar
I think the tips are too large too. Maybe if you had 5 liters of displacement...
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 04-27-2003, 01:20 PM
Steve W's Avatar
That has got to be the ugliest tip configuration I've ever seen at the rear end of a Porsche, or any car for that matter.
Old 04-27-2003, 01:47 PM
Formerly bb80sc
Vipergrün's Avatar
Hmmm, is there any chance that is a muffler for a C2/4? I dunno about those tips, though. Although, who am I to talk, folks have called my twin pipe sport muffler 'rice', 'VW', etc. Who cares....I love it
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 04-27-2003, 02:06 PM
Senior Member
Jdub's Avatar
Tim:
At the risk of offending, a pcar owner never stuffs a sock down their pants unless it won't fit.
I suppose if it were a coupe, or a Turbo, or had a 3.6 conversion you'd have a reason to advertise.
John, 1978SCTarga with no illusions...
Old 04-27-2003, 03:37 PM
Mark Wilson
Guest
Posts: n/a
It's a sign from God.
Old 04-27-2003, 03:43 PM
Senior Member
Doug Zielke's Avatar
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 04-27-2003, 03:56 PM
Sheesh you guys are hard!!
Next time I ask for opinions please make them only positive ones
Cheers
1987 930 - SOLD
Old 04-28-2003, 12:18 AM
Harlan Chinn's Avatar
Wow, Those are some big tail pipes! Why?
Harlan Chinn
Pacific Northwest Region
1998 Carrera S ArcticSilverMetallic
1982 911SC PazificBlauMetallic
Old 04-28-2003, 01:12 AM
Siena911's Avatar
Ouch, what a bummer
Don't worry, I am biting my lips hard so that I don't laugh
If I was you I would remove the rear bumper, and bolt it on, go for a test drive and see if you like the sound, have your wife blast it up and down a quiet road and you can see if you like it. That should save you the case of beer, in case you don't. But if you do, then I think a muffler shop should be able to cope with that.
Cheers Jakes
If you want to run with the big dogs, you can't pee like a puppy!!!
92 Rover Metro 1.1 (54 manly horsepower) - Dont knock it it does 60 mpg!!!
81sc / 3.2 litre transplant (Broken BIG Time )
SCWDP deserter - HP junkie wannabe
Old 04-28-2003, 01:51 AM
Deeks's Avatar
TWIN BAZOOKAS
I bet it rattles the neighbours windows !!!
Porsche-less but still alive !!!
Old 04-28-2003, 04:51 AM
Originally posted by Deeks
TWIN BAZOOKAS
Didn't get as far as firing her up yesterday but I'm going to mount it upside down tonight just to test the noise!!
I'm going to see a stainless steel welder tomorrow and have decided that I'm going to get them to remove the tips as well just to see if it looks better.
Cheers
1987 930 - SOLD
Old 04-28-2003, 05:38 AM
