'73 911 T Targa
NGK spark plug codes
Anybody know the difference between NGKBPR6ES and NGKBPR6FS?
Perhaps more importantly, are they interchangeable? |
I think ES has a removable terminal and they are different overall height and reach.
I run BPR6ES in my 3.0. https://www.ngk.com/ngk-7131-bpr6es-nickel-spark-plug https://www.ngk.com/ngk-2623-bpr6fs-nickel-spark-plug |
Flat Six
Not interchangeable.
If for your P-car, you want the ES (0.75 inch reach) not FS (0.46 inch reach). More importantly, the FS uses a tapered seat, not the flat seat plus crush washer found on the ES.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
What you really want the BCPR6ES, same plug only smaller hex so you can fit a generic sparkplug tool much easier down the head.
Magnus 911 Silver Targa -77, 3.2 -84 with custom ITBs and EFI. 911T Coupe -69, 3.6, G50, "RSR", track day. 924 -79 Rat Rod EFI/Turbo 375whp@1.85bar. 931 -79 under total restoration. |
Probably more than you eve wanted to know about NGK plugs, but helpful with subtle differences.
https://www.ngk.com/ngk-spark-plug-numbering-systems |
