Stranger on the Internet
patkeefe's Avatar
Engine compartment seal
Changing these seals is like a VW, except worse. I tried to slide the new seal through the groove, but that was impossible. So, I opened the groove (channel) a little with a prybar, but that didn't help much.
Finally, I just opened the grove completely and put the seal in. Now, I have to just go around the bottom and close it back up with a flat bar and a hammer.
I got to wondering how they did it at the factory, They probably had a special tool to pinch the groove closed.
Patrick E. Keefe
78 SC
Old 04-24-2020, 08:43 AM
After the next project
x98boardwell's Avatar
If I remember correctly I used either dawn soap or something that was slippery to slide them in, was a pain but ended up working fairly well.
Current cars: 2012 Cayenne TT, 1997 993TT, 1912 Buick Model 34, Audi S8, 1976 912E, 2016 Cayenne Diesel
Old 04-24-2020, 08:50 AM
^^ This. They would have used a liquid silicone material to slide the seals through (in fact, OEMs, including Porsche, still do this today for various rubber seals on the vehicle). Tolerances between the original seals and the grooves, at the time, were such that this would have been easily doable.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc.
'07 Boxter
Old 04-24-2020, 01:23 PM
stevie 77 930's Avatar
Make sure the channel is clean and free from debris.... Liquid Silicone made this process a breeze
https://target.scene7.com/is/image/Target/GUEST_1db44367-2385-434f-823b-943d1e3f35e4?wid=325&hei=325&qlt=80&fmt=webp
1983 911SC
1977 930 Turbo (again)
2018 GTS
2023 Audi A4
'74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone)
Old 04-24-2020, 02:02 PM
Banned
Got to lubed good!, I just did it, no biggie, Jay.
Old 04-24-2020, 07:10 PM
rokemester's Avatar
This tool is the best! Sorry but I can’t find the source. Maybe someone else will recognize. Made of tough nylon. Very sturdy and will limit damage to paint and seals. Fantastic for all seals, windshield install etc.
I just installed a new engine compartment seal. Cleaned groove, opened up sections that had been crimped. Make sure orientation matches old seal. Fit the top edge of seal and with a light Dawn soap and water mix or detailing spray for lube pressed in lower edge of seal. Work your way around the engine compartment.
Northeast Ohio
1987 Porsche 911 Targa
1966 VW Beetle, 6V
Old 04-24-2020, 08:41 PM
patkeefe's Avatar
Mine was evidently changed once before. It was crimped excessively. It became a massive PITA. But, I did it carefully, opened up slowly, and recrimped it all when I was done with a punch, strip of plywood and a rubber hammer.
Patrick E. Keefe
78 SC
Old 04-25-2020, 03:44 AM
rokemester's Avatar
On reinstallation does the engine tin go between the seal?
Northeast Ohio
1966 VW Beetle, 6V
Old 07-19-2020, 07:53 AM
Maybe something like that used to pull electrical wire? I bought some stuff for the 911 and it came in a bottle large enough to wire a 737.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 07-19-2020, 08:02 AM
Yes; one lip above the tin, one below.
'07 Boxter
Old 07-19-2020, 09:08 AM
rokemester's Avatar
Awesome, thanks. A bit of a fiddle right? One more thing to think about as you position the engine and remove all the various interfering lines.
Northeast Ohio
1966 VW Beetle, 6V
Old 07-19-2020, 11:42 AM
Actually it’s not too bad. The new rubber is a lot more pliable than 35 year old stuff...
'07 Boxter
Old 07-19-2020, 07:15 PM
rokemester's Avatar
Good point! I’m just looking for the next way this car will fight me as I get it back on the road after 6 months on a lift for suspension refresh and other odds and ends.
Northeast Ohio
1966 VW Beetle, 6V
Old 07-20-2020, 05:50 AM
I did not notice that this seal had 2 flaps while doing the drop, and was wondering about how it went back together...
Thanks!
Old 02-01-2021, 02:25 AM
rokemester's Avatar
A stiff plastic putty knife or white plastic pokey tool will be your friend. The corner bends are the trickiest but stay with it and you’ll get there.
Northeast Ohio
1966 VW Beetle, 6V
Old 02-01-2021, 07:43 AM
Prestallion's Avatar
We use these for installing rubber seals and windshields/windows. Very robust and pretty cheap.
CRL216 Tapered Stick Tool
Old 02-01-2021, 07:56 AM
rokemester's Avatar
+1, I couldn’t come up with the nice description provided. They are useful for this job and many others!!
Northeast Ohio
1966 VW Beetle, 6V
Old 02-01-2021, 08:00 AM
