Looking for hot air / heater hose clamps for 1971 911T
Hey Pelicans:
While my engine was out, I opted to replace my hot air hoses. As luck would have it, two of my original hose clamps gave up the ghost in the process. One step forward, two steps back . . . as they say.
I am trying to locate replacement clamps. My originals appear to be Norma branded, zinc-plated units with a flat head bolt. Believe the part number is: 999.512.349.02, but they don't look right on our host's site.
Does anyone know where we can get these clamps these days?
Thanks in advance!
Old 01-27-2021, 03:23 PM
The ones currently available on Pelican do not match the originals on my 1970 911T. I got some from Einmalig that do match. They have a couple styles, but the ones matching those on my car are described as Norma-Schellen clamps with a slotted cheesehead screw, and are plated in yellow zinc.
Bruce E.
Old 01-27-2021, 07:12 PM
BoxsterGT's Avatar
Porsche Crest
What are the dimensions?
I keep the small M14 and M16 Norma Hose clamps in stock and should be able to get the larger ones for the Air ducts, but do not know the size.
It should be stamped on the clamp itself along with "Norma".
Len.Cummings at verizon.net
Old 01-28-2021, 06:38 AM
Thanks, guys. Len - I shot you an e-mail, as the hunt continues.
Pretty sure these are the correct size, but my tech is saying they're not correct (shouldn't be GEMI branded?): https://www.belmetric.com/norma-torro-75-9mm-band-c-14_2154_2155_2176/cr70ylw-norma-hose-clamp-yellow-9mm-wide-p-15943.html?zenid=hkn21tkm42lqpo1qo53veg9hn5
Old 01-28-2021, 09:59 AM
Porsche Addict
I have quite a few of these.
What size are they stamped?
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 01-28-2021, 02:41 PM
This would be a huge help! I'm pretty sure they are stamped 50-70mm, or something to that effect. Just sent you a PM.
Old 01-28-2021, 03:31 PM
I have 1. This was my original,that was replated.
Old 01-29-2021, 08:18 AM
YES! That’s the one. If you’re willing to pass it along, please shoot me a PM. I’m on the East Side of LA as well.
Old 01-29-2021, 08:30 AM
Come get it. You can have it. I went with no heat on my car. I have Brian's RSR Headers.
Old 01-29-2021, 08:36 AM
Thanks, John. Just shot you a text to coordinate. That motor/exhaust setup looks mighty...
One clamp down; three more to go.
Old 01-29-2021, 09:06 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Belmetric
https://www.belmetric.com/metric-clamps-c-15/?zenid=gufejtaso14ovg2ulo8eor9q36
Kevin L
'86 Carrera "Larry"
Old 01-29-2021, 01:00 PM
skinnerd's Avatar
This is what you'll typically see sold.
They will work fine.
If you want them to look a bit more factory correct, just get them yellow zinc'd.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 01-29-2021, 03:15 PM
Porsche Addict
Did you try Bruce Stone yet?
Old 01-29-2021, 04:16 PM
I did! Bruce has been great. Thanks very much for pointing me in his direction.
Just waiting on him to confirm that he has what I'm after and then I can put this one behind me.
Old 01-29-2021, 04:20 PM
