-   -   High Beams Not WOrking (http://forums.pelicanparts.com/porsche-911-technical-forum/1084318-high-beams-not-working.html)
l_turn9 01-25-2021 12:55 PM
Hello all -
My '74 911 has a new SWK Turn Signal Switch (new last year) which worked great until recently. I have been unable to drive for a while so mostly it sits in the garage. On a rare occasion my wife will drive us somewhere to exercise it a little.
Anyway, recently I noticed the HB's no longer work. They work using the Flash Mode (pulling stalk toward me), but putting the stalk in the HB position gets nothing.
I Have read/studied the thread that shows bending the contacts to get things working again and I pulled my steering wheel to check the position of them, but they are positioned as they should be looking at the photo's in the excellent thread on this topic. The primary contact touches only one (the right one) at a time so now I'm baffled.
So I'm wondering if there's something else to look at? A few years ago I put relays in the Headlight circuits (IOW, I'm familiar with the lighting systems) and things worked great after that.
Thanks,
Larry
74 911
911.410.2368
Youroil.net
timmy2 01-25-2021 03:13 PM
My new stalk needed to be adjusted after about the same time frame.
I have the relays as well.
pete3799 01-26-2021 02:10 PM
The contacts may look like they're touching but check them with an ohm meter. I bet they are not making contact.
AlKidd 01-27-2021 10:54 AM
Save your switch. drive the lights with relays.
