-   -   Engine opening? (http://forums.pelicanparts.com/porsche-911-technical-forum/1085039-engine-opening.html)
400orbust 02-02-2021 09:43 PM
Engine opening?
Hi all. Can anyone advise what should go here to close up the hole...am I missing a piece of tin? My engine has been "backdated" so maybe with those changes something got missed? Thanks for the help.
http://forums.pelicanparts.com/uploa...1612330901.jpg
http://forums.pelicanparts.com/uploa...1612330937.jpg
911pcars 02-02-2021 10:38 PM
I believe that slot provided space for an AC compressor support bracket. You might see a few longish M6 mounting studs poking out of the chain box cover. That open space needs a short length of color-matched sheet metal (fabricated). I think the fan end of that piece slips under the engine mount bracket (painted black), then secured with screws into the existing threaded holes (M6 and ?). That piece will prevent exhaust-heated air from entering the engine compartment.
Is there a hole (about 3") on the other end of the long sheet metal piece? The hole blocked off? If so, to complete a more accurate hot air back date, source an early 911 rear sheet metal piece. The only mod needed for that piece would be to create clearance slots for each oil-fed chain tensioner tube (pass. side shown in your photo).
Sherwood
SunburntLobster 02-03-2021 12:13 AM
Hi - my 76 911S is missing most of the engine tin and also has backdated heat. I wasn't planning on replacing the missing parts, does it serve any important purpose?
911pcars 02-03-2021 01:13 AM
As mentioned in my post, those metal engine surrounds help separate engine compartment air from the heated air from the exhaust system below. Introducing high temperature air into the engine compromises the cooling needed to prevent overheating.
Suggest sourcing the needed pieces to accomplish that cooling objective.
Sherwood
sparkysvega 02-03-2021 06:47 AM
It’s where the air conditioning mounting bracket went . I made a piece out of sheet metal to cover the hole .http://forums.pelicanparts.com/uploa...1612363603.jpg
400orbust 02-03-2021 08:01 PM
Thank you both! I will fab a piece of tin to cover the hole.
