-   -   Turbo mount revisited, got to resolve this (http://forums.pelicanparts.com/porsche-911-technical-forum/108512-turbo-mount-revisited-got-resolve.html)
lendaddy 04-29-2003 06:30 AM
I test fitted the new K27-7200 last night and am posative that the turbo/muffler mount is different on this '85 exhaust than my original reactors. Does anyone have the PET showing both a '77 mount and more importantly an '85 mount? A part # would be golden. Thanks guys.
arrivederci 04-29-2003 06:44 AM
I don't have a diagram, but different mufflers have different mounts. I recently put my cat-equipped (stock) muffler on the 930 for emissions purposes and was suprised to find that it had a different mount. The cat-less mount worked both for a euro muffler and my GHL setup.
lendaddy 04-29-2003 06:50 AM
I am using a monty dual out muffler. Bu I am not concerned about that so much. It is the turbo I want located correctly. The turbo can be "moved" a little when it is mounted to the exhaust and I would like to get it right if you catch what I am saying. A small movement at the turbo could result in a fairly large change in where the exhaust tips exit.
lendaddy 04-29-2003 09:02 AM
Sorry to bump, but this one is killing me. Thanks
RarlyL8 04-29-2003 09:55 AM
I had the same problem when mounting the K27-7200.
Had to modify a used mount. There was no other way to make it fit perfectly. My exhaust is a Euro '86 with a (modified) stock muffler.
lendaddy 04-29-2003 09:58 AM
Ok, I will go that route I guess. I really appreciate your response. Don't worry Rarely I have not forgotten that I owe you one from last year as well. Once I get the engine in I will get back to that air cleaner housing project. Thanks again.
Dutchie 04-29-2003 10:09 AM
hold on :) checking for you now
lendaddy 04-29-2003 10:20 AM
Thanks, I await your response.
Dutchie 04-29-2003 10:21 AM
http://home.wanadoo.nl/eevisser/pelicans/85turboex.JPG
this is the exhaust side of an 85 turbo. does this help ?
lendaddy 04-29-2003 10:25 AM
No, that does not show the turbo mount that goes between the muffler intake and the turbo exit. Close though.
Dutchie 04-29-2003 10:33 AM
http://home.wanadoo.nl/eevisser/pelicans/85turboex2.JPG
this ? i hope its on this one otherwise i cant help you i,m afraid
MyTurbo3.6 04-29-2003 10:35 AM
Here are the 77 and 85 turbo configs...Let me know the specific part and I will give the part number
http://forums.pelicanparts.com/uploa...Exhaust 00.jpg
http://forums.pelicanparts.com/uploa...Exhaust 01.jpg
http://forums.pelicanparts.com/uploa...Exhaust 02.jpg
http://forums.pelicanparts.com/uploa...Exhaust 03.jpg
http://forums.pelicanparts.com/uploa... Exhaust 4.jpg
Dutchie 04-29-2003 10:37 AM
http://home.wanadoo.nl/eevisser/pelicans/turboex3.JPG
last try
Dutchie 04-29-2003 10:39 AM
ahhh someone who knows the turbo came in :) Good luck Lendaddy
lendaddy 04-29-2003 10:49 AM
Yes! definitely #5 in both diagrams. Could you give me both part #'s? They look the same but we will see. That is awesome, what program are you using ? Is that the PET program I have seen on Ebay? Thanks again.
Joel
MyTurbo3.6 04-29-2003 10:52 AM
930.123.121.01 77
930.123.121.05 85
I should have the later one around if you need to try one
lendaddy 04-29-2003 10:54 AM
What do you need for the mount? I could definetely use it! Thanks
MyTurbo3.6 04-29-2003 10:57 AM
How about if I send it to you and if you use it we can work it out, if not you can simply send it back and cover shipping.
arrivederci 04-29-2003 10:59 AM
Keep in mind that the placement of the turbo is also dictated by your headers. And there are four connetions to the turbo...the air intake, outlet to intercooler, exhaust inlet, and outlet to muffler. All of these other connections will limit the amount of movement you can actually achieve. If you're simply worried about the muffler tips, I suggest having a muffler shop work directly on the muffler, rather than adjusting the position of the turbo via the turbo mount.
lendaddy 04-29-2003 11:05 AM
My teory is that the mount is the only "rigid" mount and if I get that right the rest will fall into place.
beepbeep 04-29-2003 11:19 AM
Keep in mind that turbo needs a support and shouldn't be under too much force when fastened. I've actually seen non-braced turbochargers bolted on a cast-iron header "fall down" and distort the header due to intense heat turning header-material into plastic-deformation state.
Weird but it really happends.
lendaddy 04-29-2003 11:22 AM
MYTURBO, I sent you a PM
lendaddy 04-29-2003 11:36 AM
Yes Beep, I see what you are saying but if I get the correct mount and I have to tweak the turbo to get it on then I will suspect other problems.
