Dept store Quartermaster
Turbo mount revisited, got to resolve this
I test fitted the new K27-7200 last night and am posative that the turbo/muffler mount is different on this '85 exhaust than my original reactors. Does anyone have the PET showing both a '77 mount and more importantly an '85 mount? A part # would be golden. Thanks guys.
Cornpoppin' Pony Soldier |
I don't have a diagram, but different mufflers have different mounts. I recently put my cat-equipped (stock) muffler on the 930 for emissions purposes and was suprised to find that it had a different mount. The cat-less mount worked both for a euro muffler and my GHL setup.
- '72 911T - '81 911SC Euro |
I am using a monty dual out muffler. Bu I am not concerned about that so much. It is the turbo I want located correctly. The turbo can be "moved" a little when it is mounted to the exhaust and I would like to get it right if you catch what I am saying. A small movement at the turbo could result in a fairly large change in where the exhaust tips exit.
Sorry to bump, but this one is killing me. Thanks
Crotchety Old Bastard
I had the same problem when mounting the K27-7200.
Had to modify a used mount. There was no other way to make it fit perfectly. My exhaust is a Euro '86 with a (modified) stock muffler.
RarlyL8 Motorsports / M&K Exhaust - 911/930 Exhaust Systems, Turbos, TiAL, CIS Mods/Rebuilds '78 911SC Widebody, 930 engine, 915 Tranny, K27, SC Cams, RL8 Headers & GT3 Muffler. 350whp @ 0.75bar Brian B. (256)536-9977 Service@MKExhaust Brian@RarlyL8 |
Ok, I will go that route I guess. I really appreciate your response. Don't worry Rarely I have not forgotten that I owe you one from last year as well. Once I get the engine in I will get back to that air cleaner housing project. Thanks again.
hold on
checking for you now
87 Carrera Backdate |
Thanks, I await your response.
this is the exhaust side of an 85 turbo. does this help ?
No, that does not show the turbo mount that goes between the muffler intake and the turbo exit. Close though.
this ? i hope its on this one otherwise i cant help you i,m afraid
Here are the 77 and 85 turbo configs...Let me know the specific part and I will give the part number
last try
ahhh someone who knows the turbo came in
Good luck Lendaddy
Yes! definitely #5 in both diagrams. Could you give me both part #'s? They look the same but we will see. That is awesome, what program are you using ? Is that the PET program I have seen on Ebay? Thanks again.
Joel
930.123.121.01 77
930.123.121.05 85 I should have the later one around if you need to try one |
What do you need for the mount? I could definetely use it! Thanks
How about if I send it to you and if you use it we can work it out, if not you can simply send it back and cover shipping.
Keep in mind that the placement of the turbo is also dictated by your headers. And there are four connetions to the turbo...the air intake, outlet to intercooler, exhaust inlet, and outlet to muffler. All of these other connections will limit the amount of movement you can actually achieve. If you're simply worried about the muffler tips, I suggest having a muffler shop work directly on the muffler, rather than adjusting the position of the turbo via the turbo mount.
My teory is that the mount is the only "rigid" mount and if I get that right the rest will fall into place.
