Headlamp assembly falls out!
Dear Pelican community
I have recently acquired a modified 1984 Carrera. It seems the 'Lip' or tab on the top of the headlamp bowl, mounted into my GRP wings is not high enough to trap the H4 headlamp assemblies and so 'pops' out while driving. It seems to attach okay, but when I tighten the bottom screw, this has an upward push on the assembly. Which in turn, lifts the light assembly off the 'tab' I am not using a 'trim ring' - might this help or compound the issue? My options/thoughts so far: I have seen a few race or rally Porsches have a retaining tab screwed on top of the wing, pointing forward to avoid this happening, or even tape. Possibly weld an extension onto the existing tab to make it higher? Any suggestions appreciated regards, Ben
AKA "86ragtop" 1986 911 Carrera SOLD 11/2001 1984 Carrera 3.2 IROC RSR look |
Hi Ben
This thread has lots of information and links to others. http://forums.pelicanparts.com/porsche-911-technical-forum/697738-frustration-post-h4-install.html I read it before installing mine although I got lucky and didn't have too many problems. I re-used the old seals as they were in good shape. I think new seals would make the job harder. I did use cable ties behind the headlight as security. John |
Thanks John
Kinda comforting to know I am not alone with this frustration! Will read through all of these threads before next attempt All best Ben
As an alternative to the screwed in metal retaining tab, consider instead a clear bra / wrap retaining strip. To me, that would be an almost perfect solution, save for what will likely accumulate under the strip at the gap between the trim ring and the leading edge of the fender. OTOH, perhaps that space is small enough that it won't accumulate any dirt / dust or, even if it does, it won't me noticeable. Anywho, less invasive and / or noticeable than a metal tab and screws.
Frank Amoroso 911 M491 / M470 coupes: 1987 GP Wht / Blk "Apollo" 1987 Gemini Blue / Blk "Gemini" 1989 GP Wht / Blk "Vents" |
add a safety strap when you 'fix' the tab mount
use nylon cord or strap as a fail safe |
