Gasoline User
1974carrera's Avatar
What is Barrier Hose?
Periodically I see mention of folks using barrier hose when replacing the hoses in their A/C systems. Is this the original type of hose that is wire reinforced with a red braided cloth covering on the outside, or is it something different?
Bob V
1974 911 Carrera coupe Grand-Prix-weiß
1977 930 turbo Carrera coupe Hellgelb
2018 Cayenne turbo Schwarz
2019 911 GT3 RS Schwarz
Old 04-29-2003, 07:26 AM
JWest's Avatar
The original hoses had small pores, but the R-12 molecules were too large to seep out.
R-134A has small molecules and can leak out of the pores in the hose. Barrier hose has a liner that does not allow this.
James
JWest Engineering
Old 04-29-2003, 09:05 AM
Barrrier hose has an additional layer of material (nylon like compounds are best) to reduce the permeation of the refrigerant and is recommended for the newer R-134a refrigerant. If one's A/C hoses have been in use and are not leaking and one converts to R-134a due to a compressor failure or upgrade it is not necessary to replace the hoses. Apparently the mineral oil used in the R-12 systems has internally coated the hoses and stays in place since it is not miscible with R-134a refrigerant. This oil coating keeps the permeation of the R-134a within reasonable bounds. However, if a hose goes bad one should replace it with one made with the new barrier hose even if one is staying with R-12.
Old 04-29-2003, 09:28 AM
Gasoline User
Thanks for the education! Is "barrier hose" a generic term that a hose supplier would recognize or is there a specific place that I need to source it? What does it look like? Thanks again for the help.
Bob V
Old 04-29-2003, 10:46 AM
Send a message via ICQ to old_skul
It's the hose sitting in the box in my basement. I removed the A/C from my car. It's 100lb of dead weight I no longer have to cart around.
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 04-29-2003, 10:50 AM
Barrier hose is a generic term; many different manufacturers produce it. I know of an online source which sells it in small length coils. One has to have access to a bubble crimp tool (not cheap) to install the recommended bead lock type fittings on the barrier hose. Jim
Old 04-29-2003, 11:07 AM
Removing the A/C also provides the additional weight reduction of between 100 and 150 lbs by eliminating the female passenger. Jim
Old 04-29-2003, 11:15 AM
Well, Jim, she can still ride. She just has to wear less clothing. Or none at all!
Mark Szabo
Old 04-29-2003, 01:43 PM
