Crazy powder coat removal
So, this is really awesome. I picked up another headlight bracket due to one of mine was not the original style and did not match. EBAY for $20 delivered so that was fine.
The problem was it was powder coated. Looked good but not does not match my other one. Next challenge, How does one remove powder coating? Blasting Cabinet? = NOPE Bench Grinder? = NOPE Paint Stripper? = NOPE OK, Drastic measures. Years ago I used some Aircraft Stripper that worked great. I picked up some a few months ago and it wan nothing like before.. Did not do squat. I researched why, seems they had to remove some of the chemicals that did the stripping. Methylene Chloride- Well, why cant I put it back in. Ordered some online and some Formic Acid. Another ingredient. Seems Methylene Chloride dissolves powder coating. I mixed 75/25 Methylene and Formic acid and HA! Soaked the piece for 15 minutes and the coating fell off. CRAZY COOL! Last edited by Carl S.; 02-13-2021 at 04:54 AM.. |
I'm good with tools.
I've had luck, with small parts, using heat around 600-700 degrees. Never tried a larger part.
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 02 996 4S (owned since new - heavily optioned) |
I love that info
Thanks Ian
Kermit, 73 RS clone, Just Part of the Team Chris Leydon ,Louis Baldwin ,Peter Brock ,Riche Clark Jerry Sherman ,Rob McGlade ,Donnie Deal Hank Clarkson ,Craig Waldner ,Don Kean ,Leroy Axel Gains |
(man/dude)
Great recipe!
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
I used goggles, gloves, jacket and a respirator. Did it outside and only brought it in to take the pictures as it was at night.
I do not have a much of a need for this type of stuff. Only once in a while. Just thought is was cool. |
Good to know. Colombia makes a powder coat stripper but they only sell in 5 gallon pails
It's a 914 ...
Good info, thank you for sharing. Be damn careful using this stuff of course. If it does that to paint, imagine what it does to lungs, skin, eyes, your kids, etc.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Not sure what APR is?
I do not recommend this method as I do not know how safe it it. I practiced safe handling ,it is an acid. I only had one piece to do and was amazed at how well it worked and thought I'd share my experience. I strained the chemicals and stored them in the large glass jug. If someone else would like to take it further that would be great. I am back to plating front calipers. Dang, they are tricky. Last edited by Carl S.; 02-16-2021 at 04:33 PM.. |
What kind of rinsing will you do to ensure there are no traces that will affect future coating efforts?
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
Airplane Paint Remover
I understood you had that and used it as a base for your mixture (?)
I did a simple water dunk in a 5 gal. bucket, rinse under the sink. I will do a quick etch in diluted muriatic acid and water rinse.
I plan on media blasting, then apply a coating. This mixture was just the Methylene Chloride and Formic acid. All the APR that are sold over the counter had the Methylene Chloride removed. Thus they no longer work. I do not know what else was removed. But when you look on the shelves most of the strippers/removers say "non-Methylene Chloride" I do have a gal of the newer APR and tried to add the MC and Formic Acid back into it. IT worked better but I do not think I added enough. |
We used to use a mixture of Methylene Chloride and Hydrofluoric Acid to strip parts. Works well but is insanely caustic. Fumes, contact, the smell, etc... awful stuff.
We now use a product called Greensolv. Works better than any of that. Strips faster, smells tolerable, doesn't eat your bones away, etc lol.
1968 912 - widebody - 3.2 - 915 - endless build 1980 911 - targa - barnfind nightmare - gone 1985 911 - targa - barnfind nightmare - gone 2017 991 - C4S - summer daily - for sale IG - therealcarwash |
Greensolv? I will look into that. Can it be purchased online?
Out of Canada. Contact them directly. Has to be heated to 185 degrees to be effective. Pricey. 55 gallons is $2250.
Our operation...
