-   -   Tune Up Questions (http://forums.pelicanparts.com/porsche-911-technical-forum/1085773-tune-up-questions.html)
3 pedals 02-11-2021 11:45 AM
Tune Up Questions
SmileWavyPelicans, I putting in a new rotor, cap and plugs today. My car is a 79SC and has the 6420 MSD box installed by PO. Stock as far as I know. The old plugs were Bosch WR5DC gapped at .032. I ordered Bosch WR8DC from our host. My research says the new plugs because of the MSD box should be gapped at 1.27mm to 1.49mm. (If my conversion to inches is correct), that translates to .050 to .058 in. Also, the WR8DC are a hotter plug-correct? Is that going to be an issue or not? This forum is great!! Thanks in advance Kip
3 pedals 02-11-2021 05:38 PM
How Bout You Big Boyz??? AL, Walt, Glenn. No one else thought this important, but it is to me. Such a simple question eh?
fanaudical 02-11-2021 09:20 PM
Disclaimer - I don't have an MSD ignition but have certainly researched it (may be a future upgrade). A few questions:
- Which engine in your SC? 3.0 with all stock setup? If so, then I think the WR8DC is the current stock plug. Not sure why somebody was running 3 heat ranges cooler unless they were running a lot more advance or something. Where is your timing set?
- Which coil are you running with the MSD box? Generic guidance from MSD does state 0.050-0.060 gap for a starting point for engines with 10.5:1 or less compression.
3 pedals 02-12-2021 07:52 AM
tune up questions
Fanaudical, thank you for the reply! It's a 3.0L, believed to be stock., so 8.5 compression ratio. The coil that's on it is a Bosch #0221119027 blue coil. I haven't checked ignition timing yet, but will do so after plugs, cap and rotor are installed.
fanaudical 02-13-2021 08:04 AM
You might investigate a different coil. Here's an older thread where this was discussed; it seems a matched MSD coil might be a better option.
http://forums.pelicanparts.com/porsche-911-technical-forum/245698-can-i-use-bosch-red-blue-coil.html
With the blue coil, you might start with stock gap and slowly open that a bit (.005" increments). Some other threads point to running less than 0.050" gap with MSD.
proporsche 02-14-2021 02:09 AM
there should not be WR8DC but W8DC, not with the resistor...
Ivan
3 pedals 02-14-2021 10:47 AM
Ivan, thanks for chiming in! When I ordered the tune up parts for my 79SC 3.0L from our host the web page said WR8DC were the plugs that were shown for my car. I didn't talk to parts and assumed the web page was correct... Am I missing something here??
Kip
proporsche 02-14-2021 11:35 AM
yup ,it seams they do not make those any longer.
Bosch Spark Plug W8DC - Each
Supersceded to WR8DC+
it is what it is
Ivan
3 pedals 02-14-2021 01:18 PM
Guess I'll do my due diligence next time. Thanks to those that offered feedback. It was appreciated!!
Kip
