-   -   sources for 3" diameter velocity stack screens? (http://forums.pelicanparts.com/porsche-911-technical-forum/1085864-sources-3-diameter-velocity-stack-screens.html)
70SWT 02-12-2021 12:22 PM
I could use a set to fit the Racehead Engineering ITB stacks that are 3" across. Rama has nothing. Rimmer Bros doesn't have the right sizes. I was referred by Al Kosmal to Pierce online, but they want $55 each. $330 seems a little steep for six bits of cut screen with rubber surrounds. Hopefully there is another option.
Joe Bob 02-12-2021 12:52 PM
That's what they go for. Pegasus wants 59 each. Bend over Porsche tax. No kiss or reach around. You could probably source the rubber at Mc Masters and screens as well. Cut and snip.
70SWT 02-12-2021 01:05 PM
Good thought. Then I might be able to layer the screen for a bit of extra filter effect, as some of the regular-diameter filters are made.
vitalstat 02-12-2021 01:09 PM
Check some bike shops online
jpnovak 02-12-2021 02:49 PM
motorcycle stack filters. Some are just as expensive. Some are cheaper.
I had UniFilters on my ITB stacks for a long time. Flowed great. oiled foam with internal springs to prevent collapse under airflow. Just slip on and tighten the collar.
supersignman 02-12-2021 02:53 PM
Maybe look in the Volkswagen world?
jac1976 02-12-2021 03:09 PM
America’s own fancy-shcmancy kitchen utensil company...
https://www.amazon.com/OXO-Good-Grips-3-Inch-Strainer/dp/B001713L84/ref=asc_df_B001713L84/?tag=hyprod-20&linkCode=df0&hvadid=167134584690&hvpos=&hvnetw= g&hvrand=455169078474736628&hvpone=&hvptwo=&hvqmt= &hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9028050&hvta rgid=pla-274772305578&psc=1
And some Trim Lok or similar
Coblue 05-29-2021 08:02 PM
Try PJ Motorsports. ( google them )
Hi_Fi_Guy 05-29-2021 10:19 PM
Will these work for your application? I used to run them on a vintage racer (non-Porsche).
Velocity Stack Filters
https://www.cbperformance.com/product-p/6373.htm
Geneman 05-30-2021 05:53 AM
Does anyone know if any of the filters mentioned in this thread will fit porsche PM0 50mm stacks
thanks. frank
burch 05-30-2021 06:53 AM
tea strainer
http://forums.pelicanparts.com/uploa...1622382689.jpg
3 1/2" tea strainer, amazon
1" of bike inner tube
