-   -   Non Running 1988 911 Need Help (http://forums.pelicanparts.com/porsche-911-technical-forum/1085922-non-running-1988-911-need-help.html)
pete3799 02-27-2021 04:45 AM
Yup it will smoke big time for a while.
Pedro '84 Coupe 02-27-2021 06:13 AM
Originally Posted by Norm1966 (Post 11241568)
Thanks for all your help guys I pulled the injectors and built a little test rig with a spray can and some hose. I saw a pretty cool You Tube video and was able to get them to fire but they were definitely clogged. after getting them to fire they were shooting a straight stream of fuel so sent them to a specialty fuel injector service shop.The shop is called Southbay Fuel Injection in Merrick LI, NY. They did a fantastic job cleaning them flowed them before and after with a Dyno sheet included all for $130. I reinstalled them and the car fired right up. Car was sitting for 22 years and it’s smoking like crazy. I’ve heard that oil seeps into the exhaust after sitting for a long time on these engines and takes quite a while to burn off. Does that sound right to you guys?
Thanks very much for the help feels great seeing this car run after so many years
Good job! Any pics of the car?
Flojo 03-01-2021 02:08 AM
that well may be.
drive it some spirited miles and see if it stops
GaryR 03-01-2021 03:36 AM
That well may be why the car was parked 22 years ago, Carerra valve guides are notorious for failing. Run it (hard) for a while and see, but if leaving it parked for a day or so causes a smokescreen it's top-end rebuild time..
