Oil Cooler Seals & TSB Question
Cleaning up the oil cooler to add seals (green viton) but would like someone to have a look at these pics and advise if I need to do the TSB as well.
I can’t see the cast-in pipe, it looks as if it is completely sealed by aluminum with no cracks or voids.
The outside looks like there is a void, but couldn’t get my camera in there to take a pic.
Would appreciate an experienced opinion here, thanks!
Edit: 84 Carrera
1984 M491 Coupe
2014 Cayman S
Old 02-13-2021, 10:08 AM
Has not leaked yet!
Mine was leaking and it was apparent.
Old 02-13-2021, 10:56 AM
proporsche's Avatar
you can apply some JB weld but in your case you have later model of 911 so it is sealed..put the year and model in your signature so people will know what are you asking about and for..
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-14-2021, 01:16 AM
Strange, all of my posts usually display a signature...
My car is an 84, I thought this was included in the TSB?
1984 M491 Coupe
2014 Cayman S
Old 02-14-2021, 02:34 AM
proporsche's Avatar
i do not know what is TSB?? you add your 911 in the garage..link
Old 02-14-2021, 02:51 AM
The Technical Service Bulletin that is referred to quite often on this forum.
Not sure why my Sig line sometimes doesn't show up. I have one setup in my control panel, and the box is checked to "Show Your Signature" when I post.
Just went back and turned them on manually...weird.
1984 M491 Coupe
2014 Cayman S
Old 02-14-2021, 04:28 AM
proporsche's Avatar
yes the update is for mainly 911SC models and some Carrera did leak .your does not leak like i said you can put on JB weld if you feel better about it;-)The bulletin came out really very very late with that update modification;-)
Ivan
Old 02-14-2021, 04:36 AM
Thanks @proporsche and @911obgyn !
1984 M491 Coupe
2014 Cayman S
Old 02-14-2021, 04:45 AM
