Oil Cooler Seals & TSB Question
Cleaning up the oil cooler to add seals (green viton) but would like someone to have a look at these pics and advise if I need to do the TSB as well.
I can’t see the cast-in pipe, it looks as if it is completely sealed by aluminum with no cracks or voids. The outside looks like there is a void, but couldn’t get my camera in there to take a pic. Would appreciate an experienced opinion here, thanks! Edit: 84 Carrera ![]() ![]()
1984 M491 Coupe 2014 Cayman S Last edited by Quasimoto; 02-14-2021 at 03:29 AM.. |
Has not leaked yet!
Mine was leaking and it was apparent. |
you can apply some JB weld but in your case you have later model of 911 so it is sealed..put the year and model in your signature so people will know what are you asking about and for..
Ivan
1985 911 with original 501 708 miles...807 421 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
Strange, all of my posts usually display a signature...
My car is an 84, I thought this was included in the TSB?
1984 M491 Coupe 2014 Cayman S Last edited by Quasimoto; 02-14-2021 at 03:28 AM.. |
i do not know what is TSB?? you add your 911 in the garage..link
The Technical Service Bulletin that is referred to quite often on this forum.
Not sure why my Sig line sometimes doesn't show up. I have one setup in my control panel, and the box is checked to "Show Your Signature" when I post. Just went back and turned them on manually...weird.
1984 M491 Coupe 2014 Cayman S |
yes the update is for mainly 911SC models and some Carrera did leak .your does not leak like i said you can put on JB weld if you feel better about it;-)The bulletin came out really very very late with that update modification;-)
Ivan
1985 911 with original 501 708 miles...807 421 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. Last edited by proporsche; 02-14-2021 at 05:10 AM.. |
Thanks @proporsche and @911obgyn !
