Annoying door clicking
My SC’s driver’s side door has that awful clicking sound when opening and closing. I know there’s a lots of advice on fixes for this, but is there any reason that I just couldn’t remove the check arm from the pin on the a-pillar? Would that affect any of the door stability or support? I did this on my suburban door, and it worked out fine.
Old 02-04-2021, 06:31 PM
Replace the pin with a 6mm bolt ane nylock nut and tighten until it shuts up. Then see if the area in the door where it mounts is still tight and solid. Lots of doors need a serious repair in there. Some just need the nuts or bolts tightened up.
206 637 4071
Old 02-04-2021, 07:01 PM
I had a terrible popping sound when I opened the door on my SC. I did as John described and completely eliminated the problem. Amazing!
Hugh Lindberg
1972 911
1970 Alfa Romeo 1300 GT Junior
Old 02-05-2021, 04:45 AM
The bolt is a great first step, but the door click will most likely come back unless you do the doorstop rubber shave mod detailed elsewhere on this forum.
The factory put way to much tension into the door stops.
Old 02-05-2021, 05:55 AM
Tighten the nut more if it comes back.
206 637 4071
Old 02-05-2021, 05:58 AM
How many times? 3 was my limit
edit: TBH, I looked at the doorstop mod years ago and thought, "I don't need that". But years later after fighting the doorstop issues on several cars, including the saver plates and torn metal I reconsidered. It is a good mod that resolves all the issues, include the door sheet metal problems.
Old 02-05-2021, 06:02 AM
Or drive in a door stop pin all the way (freeze it first.)
Old 02-05-2021, 07:57 AM
I appreciate the information. But why can’t I just disconnect it from the pin? I don’t really care about having a door stop.
Old 02-05-2021, 07:57 PM
If you do that, the whole thing should be removed, or the arm can get kinked and bend the door hole.
206 637 4071
Old 02-05-2021, 09:25 PM
Fine with me. Will the door loose any support or stability?
Old 02-05-2021, 09:52 PM
proporsche's Avatar
nope ..just your hand;-)
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-06-2021, 12:27 AM
Registered Minimalist
75 911s's Avatar
You could hyper extend the door causing thousands in damage to the door if you remove the strap. Wind.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-06-2021, 03:55 AM
Then I’ll just hang onto the door when it’s windy. 💨💪
Old 02-06-2021, 11:03 AM
proporsche's Avatar
kansas..i would suggest to you fix it..because..and you can trust me..one day you will forget and your door will swing so far away that you will be sorry.....
Ivan
Old 02-06-2021, 11:15 AM
Gotta an idea. What about attaching an industrial grade spring from the door stop arm to the pin hole? It’d be long enough to be able to open the door easily but strong enough to prevent the door hinge from hyperextending.
Old 02-06-2021, 03:01 PM
Fabric or leather strap. Lots of vehicles have used these over the years. Simple, light, effective
Brian Miller - Scottsdale, AZ
1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S
Old 02-06-2021, 05:10 PM
the suburban hinges have stops built into the hinges. I dont think the 911 door has them so the only thing to stop it would be the fender. I dont think a spring would work there is nowhere for it to go when closed. I fixed my door with big washers and i think i made a cutom plate to disperse the load. Its a pain to fix but if you put in the effort to do a good job it will last a long time.
Old 02-06-2021, 06:31 PM
I had the same damn issue w my 993 and tried all sorts of mods to the pin and washers. Nothing worked and I ain’t spending a grand at a body shop sorting this issue. I think I’ll just do the leather strap fix. It’s not ideal but I don’t care. Can’t stand the awful popping sound every time I open the door. And I personally think that over time, this condition is going to screw up the door and end up breaking off the pin plate from the panel.
Old 02-06-2021, 08:04 PM
Dr J's Avatar
I would not recommend going without any kind of door stop. I did that for a while and every time I opened the door I had to be conscious it would not swing and hit another car or swing all the way open and overstress the door by the hinges. If it gets away from you just once, you will kick yourself for it.
I ultimately went with the replacement being sold here which was quite stiff and made its own annoying noises until I operated on it as per multiple threads on this board.
1979 SC, Slant nose wide-body cab conversion. AEM Infinity EFI, COP, supercharged!
Old 02-07-2021, 03:56 AM
proporsche's Avatar
maybe by now Kansas will know what is the right thing to do ????got plenty of warnings,thou............
Ivan
Old 02-07-2021, 04:31 AM
