Thread Killer
Teutonics's Avatar
Cost of A/C service?
It's that time of year again, temps are starting to creep up..... and I need to finish the A/C repair.
I've replaced the compressor, two leaking lines (P.I.T.A.!), and ALL of the O-rings. Now I just need to get the system flushed/evacuated, vacuum test, and refill with refrigerant. What kind of $$$ should I expect for this service (cost of refrigerant excluded)?
Looking forward to being (cool) this summer.
T.I.A.!
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 04-29-2003, 05:45 PM
I have been getting my system refilled about twice a year here in Houston even though I have replaced many of the components including evaporator, evaporator pipe to cabin, pump and a couple of hoses. The hoses I have not replaced are the two that go from the compressor to the front condenser. Anyway I spend about $200 or so each time I go to the garage for the service. Until this year. This year I was in south Texas on business so went across the border to get the system charged with R-12. Cost was $9 per bottle (it took 2 bottles of DuPont R 12) plus evacuation for $17. Runs cool now. Will let you know how long it lasts.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not.
2012 BMW 528i (wife's)
2007 Toyota FJ (rain and off road days)
Old 04-29-2003, 06:04 PM
If you're looking for R-12 service like you describe but "north of the Border" I would estimate your cost will "start" at $200. Jim
Old 04-29-2003, 06:34 PM
My bill from TRE of Hollywood says "A/C recharge", $120. It works fine. I still have the original compressor from '87. They charged up the A/C and let it set for several days. No leaks. I have cold air now.
Caliber
1987 911 Cabriolet
Old 04-30-2003, 08:55 AM
"A/C recharge" is likely much different than flush, evacuate, vacuum test, and refill with R-12. Having done a little of this work myself I conjecture for $120 they hooked up a gage set, maybe "sniffed" for leaks, added some refrigerant and then rechecked it with the gage set a few days later. A minimum, decent flush on a typical 911 means disconnecting two condensers with all the risk of not being able to restablish a good seal if there are flare fittings, replacing the receiver/drier, evacuating and leak checking for at least an hour (three hours is better), determining and replacing missing oil, then properly re-filling the refrigerant by watching gage pressures or weighing refrigerant going in. Cheers, Jim
Old 04-30-2003, 09:39 AM
