-   -   Trivial Question, 3.6 Turbo (http://forums.pelicanparts.com/porsche-911-technical-forum/1086458-trivial-question-3-6-turbo.html)
GG Allin 02-18-2021 04:38 PM
What engine case does the 1994 Turbo 3.6 use? Same as the 3.3 or 964?
Dan J 02-18-2021 05:53 PM
Neither it's unique
RarlyL8 02-19-2021 06:48 AM
964C2T3.6 uses the 3.3L 930 engine with larger P/C to increase the displacement to 3.6L. Also uses the same CIS system which is last year for that as well.
Dan J 02-19-2021 07:43 AM
Both the 964 3.3 and 3.6 have unique cases in addition to many other unique parts
The reason I know is I needed one of each
MikeD930 02-19-2021 01:16 PM
Is the 964 3.3 case different from 930 3.0/3.3 cases? If yes, how so if you don't mind sharing its differences.
RarlyL8 02-19-2021 02:54 PM
There are many unique parts but I don't believe the case is unique, other than the type number. It may have been modified to fit some accessories however the reason for using this engine was to reduce costs associated with adapting a turbo to the 964 engine and fuel injection system.
Dan J 02-19-2021 04:40 PM
The case is definitely different then a 930/3.2 case internally and externally
RarlyL8 02-20-2021 08:20 AM
In what way?
Dan J 02-22-2021 07:29 AM
964 uses a crank sensor no provision for that on 930 case at the least
