Classic Retrofit fuse block has no power to two fuse terminals?
I have installed the front and rear fuse blocks with no difficulty but find that terminals #16 and #21 (counting from the front of the car) have no power to them. Any ideas about what would cause this? Anyone know of a link between these two terminals? Since the wiring is very tight, I would rather not try to remove the block to look at the back of it. Any comments will be greatly appreciated.
ROW '78 911 Targa
Normal.
16 is fed by a jumper for later years. (Fuel pump relay) 21 isn’t used unless it has power Windows and is fed with a black wire from the PW relay. Your car a 74? Here ya go. https://www.dropbox.com/sh/s292jtsyvl6llw2/AABF-ofgMfoMltGa99Asphr5a?dl=0 Supplementals for options: https://www.dropbox.com/sh/hr6dquonkwjp23a/AABjbboPo-4J2L9nBoC5tbh6a?dl=0
Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. Last edited by timmy2; 02-22-2021 at 12:15 PM.. |
Thanks Timmy2, as usual, for the quick reply. You are always most helpful and appreciated on this forum.
