Bouncing Idle on startup, 3.2
My 3.2 Targa started acting up the other day, with the idle bouncing on cold start, and hanging up above idle after revving it. The car has a SW chip, MK cat bypass and sport muffler. It seems like it went from running perfectly to this, and I noticed it after washing it. I didn't get the engine compartment wet at all, but opened it to wipe it down. I'm guessing I may have pulled something, created a vacuum leak, or done something to the idle control valve. I just had an oil service a couple hundred miles ago. It gets better once it's warm, but still doesn't feel exactly normal to me.
Here's a video clip. I'm revving it about halfway through the video, and you can see the revs hanging around 1200-1300. Idle typically 800-900.
2018 Porsche 911 GT3 manual
1984 Porsche 911 Carrera Targa
2021 Porsche Macan GTS
2018 BMW R1200GS Adventure Rallye
2020 Ducati Scrambler 1100 Sport Pro
Old 04-02-2022, 10:50 AM
Brew Master
cabmandone's Avatar
If it just happened after you washed the engine bay, the first thing I'd so is double check all electrical connections. I bumped my CHT connection once and went from running well to crap in the blink of an eye.
Nick
Old 04-03-2022, 05:01 AM
Jeff Alton's Avatar
ISV may need cleaning. Or, and adjustment to AFR is required. May also have a vacuum leak.
Cheers
www.turn3autosport.com
Old 04-05-2022, 07:46 PM
Administrator
Matt at Pelican Parts's Avatar
I would recommend starting with checking along the intake. It behaves sort of like a vacuum leak. You could smoke test it and look for anything obvious.
-Matt
Old 04-06-2022, 02:32 PM
