rear sway bar bushing help
i do not know which sway bar bushing to purchase for my 1975 911S targa. Itt is an early targa
i bought 4-91134379203 but they are way too big, have not clue why I bought them as the pet lists 2 types 91133379302 91133379302 the originals look like 91133379302 but they both say 18mm which i have any clue as to which ones to purchase?
1975 911S Targa Silver Anniversary Edition |
Slow old car
Your best bet is going to be to measure the bar with a caliper, and then order by size rather than number.
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
For example, the correct part number for a SC bushing is too small and will bind. The 930 pn is correct for the SC. Buy a few and return what doesn't fit? |
thanks for the responses, will post my findings
Location: behind the redwood curtain, (humboldt county) california
check the bar mounts, failure fairly common
"While you are in there", carefully check the bar mounting brackets attachment to the chassis. My dad's 74 was driven very conservatively, yet at some point one of the mounts failed and his shop just removed the bar.
When i inherited the car, i installed the Wevo mounts, which required the bigger, later style bushings and attachment straps. good luck, chris |
FWIW, my car has Weltmeister sway bars front and rear. The bushings were missing when I got the car. I removed the end links and brought them to a local machine shop who turned me new ones out of dense polymer material. Might have been Delrin but he wasnt sure what was in his junk drawer. Was $40 with a beer discount and conversation about cars. Might save you a bunch of ordering and waiting. Guy spun them on the lathe in under an hour.
Thanks . Ill check connections
sway bar and end link bushing part 911 333 793 02 fits my 1975 911s. The bar is 18mm.
