Engine Compartment Temperature Probe
I know someone has measured an engine compartment in 110F heat under load and under idle at rest over time. Contrary to common perception, an air cooled compartment should be much cooler than a water cooled compartment.
I am guessing inside the shroud might be 130F and on top of the sheet metal will be mostly close to ambient, unlike your standard water cooled car where the air behind the radiator might be 140 and the center of the hood might reach 170 Some random standards for components that seem to exist: Coil-on-plug -20 to +140C Ignition driver for -40 to +120C ECU -25 to +85C Regulators -40C to +140C Starter Cable Near Manifold 205 C ( 400F) Dash Panel 140 C ( 285F) on Engine (Typical) 150C ( 300F) Choke Housing 205C ( 400F) Exhaust Manifold 650C (1200F) I am looking for something similar to this data: ![]() ![]()
positions 1 and 2 could be very "cool"
I just placed 4 additional thermistors in my engine bay this winter and one ambient inside the front bumper but will not have any data for a while. I have one measuring engine bay air temp in front of the fan, one in the intercooler core at the distal end, and then one on the fuel rail and one on a fuel injector. That is in addition to preIC IAT, post IC IAT, and cylinder head temp. If there is any interest, I can certainly post the data throughout the year. These are also easily relocated if there are any specific requests.
Steve Sapere aude 1983 3.4L 911SC turbo. Sold |
AutoBahned
sjf011 - I'm interested; hope you will do idle, at speed, etc.
- themistors?? very old school... 1968SWTs - I'm curious where the diagram is from (not the R&T base, but the colored parts) |
the colored parts are just me the talking monkey with a paint brush - just a wild guess
I would love to have data for these two points!
![]() thanks
Thanks |
Location: behind the redwood curtain, (humboldt county) california
Air pressure sensor???
Slight hijack, but similar interest.
Can you recommend an air pressure sensor??? I am curious about the hoped for increase in air pressure in the engine compartment, at various speeds, with the stock engine lid and a duck tail. I have read a few posts indicating reduced engine temps with the Duck. It would be nice to quantify this at various speeds. IIRC, i've read that a duck will reduce drag, lift and move the aerodynamic center of pressure rearward on the car. |
As another data point, once upon a time, I inserted the end of a thermocouple wire from my Fluke DMM inside the intake airbox. The temperature at speed was basically ambient - same with the engine compartment temp. Thus, the ubiquitous default "cold air intake" in our cars is active when the air temperature is whatever it is.
OTOH, excessive heat soak after engine shutdown can be controlled by a temperature sensitive relay that controls a fan motor attached to the grill. Sherwood |
AutoBahned
At any speed/boost conditions, IAT doesn't exceed ambient by more than 5F or so. If I stop with the motor hot for a few minutes (say 10), intercooler heat-soaks 20-30 degrees C. Just driving along city streets for 3 minutes - heat soak gone. Any freeway speed or moving == IAT reads ambient. As long as the wastegate isn't open. The MOTEC mounted in the engine bay monitors its own temperature; that's also ambient, or close to it (the vibration mounting stops it getting rid of heat, but it starts off agreeing exactly with the IAT and gets warmer). Sit idling for 15 minutes, the MOTEC temperature alarm (200C) trips for the CHT reading. And the engine bay feels like putting your head in an oven if you check the oil level.
'77 S with '78 930 power and a few other things. |
https://www.google.com/search?q=early+vehicle+aerodynamics%2C+pitot+manom eter&tbm=isch&ved=2ahUKEwinp43-r4bvAhUJGzQIHWSPBB0Q2-cCegQIABAA&oq=early+vehicle+aerodynamics%2C+pitot+manometer&gs_lcp=CgNpbWcQA1C6PFi-amCFcmgAcAB4AIABW4gBrQySAQIyMpgBAKABAaoBC2d3cy13aX otaW1nwAEB&sclient=img&ei=nEs4YKfpOIm20PEP5J6S6AE&bih=1125&biw=1633 This is a rig that's a little more contemporary. ![]() |
Thanks Rweb and 911pcars. Quite a range of instruments. I'll do a little more looking around. I used two 4 cyl motorcycle manometers taped to a board to sync 4 2 bbl Webbers after a rebuild - worked fairly well.
chris |
I would be interested to know what temperature the engine mounting crossbar gets to if anybody knows.
Outlaw .... by definition ..... does not follow rules well www.FloydDesign.ca https://www.youtube.com/watch?v=sV5aIALWlG8 |
