LinkBack | Thread Tools | Rate Thread |
Kind of Blue
I'm back in a 911 and some 15x7 tire rub/shock questions on a hot rod
So I've decided I'm done with non-Porsche toys. I tried to think my Lotus could be a 911 and while it is an amazing little machine, it isn't where my heart is at.
Fortunately, I had the opportunity to purchase a very nice '71T hot rod with a very punchy 2.7 out of a '77. The shocks are definitely in need of replacement and it's wearing some old 196/65/15 P6000s on a set of 15x7 Fuchs that I will be replacing. I note on hard turns they do lightly rub the outer rear fender wells. I have read 500 threads on this basic issue but do you think going to 205/55/15s will remedy this issue? I'm noting the big, bulbous sidewalls seem to be the culprit of the rubbing more than the top of the tire, so I'm hoping a half inch of height shaved off and smaller sidewalls will remedy the issue. Also, I think the car is wearing uprated torsion bars of some sort and a set of tired Konis. Shall I replace with HDs or Sports? It's great to be back! The car otherwise drives like a dream. ![]() ![]()
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor Last edited by MrBonus; 02-27-2021 at 06:08 AM.. |
(man/dude)
I would say, at first glance, I wouldn't change a thing!!!! A little rubbing on the inside is no problem IMO. But you you could add 5mm spacers in front without much trouble to lessen it perhaps.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
Kind of Blue
Sorry, I clarified the rubbing is in the rear fenders! Also, thank you.
1971 911T w/ a 2.7 (ITBs, EFI, a bunch of other stuff, 2180 pounds with fuel) 2024 Ford Bronco Raptor |
I would rather be driving
I think you need some rear negative camber. This will pull in the top of the rear wheels/tires and give you some more clearance.
The front quarter picture almost looks like you have positive rear camber. Though this could just be angle of photography. Beautiful car!
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Kind of Blue
Can you tell where it is rubbing?
Is it rubber on the lip? This means the tire is too far outboard. Too much camber is usually the top reason. Could also be too wide spacer (if any) , too wide wheel (or offset), or too wide tire. Is it rubbing further up on the underside of the fender? This means that you do not have enough spring rate, the tire is too wide or the tire is too tall. Or a combination. The 65 series tire is quite tall. Is it rubbing on the front or rear edge? This could be incorrect toe settings.
Kind of Blue
Kind of Blue
Also, I'd rather not change the wheels because frankly, they just look fantastic.
a 215/60 which is a tad wider and taller will rub in the same place any of the following will be ok 205/55 @ ~23.9" 205/50 @ ~23" 195/60 @ ~24.2" 195/55 @ ~23.4" Additionally Bilstein Sport rear will help, these work well w/ Bilstein HD front Check T- bars too, 20/26 w/ S or SC sways is a very nice street setup
Kind of Blue
Kind of Blue
So it looks like the Sport Bilsteins are only available for the '72 and on cars. I'm stuck with HDs as my sole option.
Part Number: 24-009676 Series: B6 Performance Notes: - Club Sport Version - Setting: 1800/1645 - For use with M14 lower mounting bolt 24-009676 Part Number: 24-009737 Series: B6 Performance Notes: - Rally Version - Setting: 2855/1400 - For use with M14 lower mounting bolt Part Number: 24-009751 Series: B6 Performance Notes: - Sport Street Version - Setting: 3365/1645 - For use with M14 lower mounting bolt Part Number: 24-001670 Series: B6 Performance Notes: - Standard Version 1 - Setting: 2385/1330 - For use with M12 lower mounting bolt Part Number: 24-001694 Series: B6 Performance Notes: - Standard Version 2 - Setting: 1965/1330 - For use with M14 lower mounting bolt Part Number: 24-595452 Series: Motorsports Notes: - RSR Version 1 - Setting: 1800/1700 - For use with M14 lower mounting bolt - Requires additional components and racing springs Part Number: 24-617321 Series: Motorsports Notes: - RSR Version 2 - Setting: 2400/1800 - For use with M14 lower mounting bolt - Requires additional components and racing springs
Kind of Blue
Rear https://www.pelicanparts.com/More_Info/24001670.htm?pn=24-001670-M512&SVSVSI=911E&DID=12989 Front https://www.pelicanparts.com/More_Info/P36112.htm?pn=P-36-112-INT&SVSVSI=911E&DID=48034
Kind of Blue
Sorry, I'm on Bilstein's site, and all '69 - '71s use the M12 mounting bolt, correct? I don't want to accidentally order the wrong item.
from '72 on it is M14x1.5x95
RETIRED
65 series tires are way too tall for spirited carving of turns. 55 or 50 would be a better fit.
