Updated ignition system
Can anyone help,
I have installed a CDI Ignition unit into a 1970 Porsche 911 and left the existing Bosch coil in place. Should the coil be upgraded to support the new ignition system? |
you should have a black Bosch 0221121001 and 0221121006
or optional MSD Blaster HV 8222 |
You should consider an MSD ignition unit since they product dual spark and can rev limit. You should also consider the Pertronix magnetic pickup as a drop in points replacement. You'll notice a significant improvement in cold starts and general smoothness.
I have:
Partsklassic coil Partsklassic digital cdi with rpm cutoff Pertronix electronic ignition. I believe a 70 should have had cdi? If not you want a coil designed for cdi. Ditch the points. |
Thanks for all the help, much appreciated
| All times are GMT -8. The time now is 04:07 AM. |
