-   -   Idle Bouncing (http://forums.pelicanparts.com/porsche-911-technical-forum/1087663-idle-bouncing.html)
isby 03-05-2021 07:49 AM
Idle Bouncing
I have read some threads on this, but I still don't have a clear answer. My '84 3.2L starts fine and idles correctly (once warm) at about 850 rpm. However, if I hit the accelerator and then let the rpms drop back down, the idle hunts and surges (feels more like huffing and puffing) for a few seconds within a range of about 600-900 rpms until it settles back to about 850. Idle control valve?? Your collective wisdom would be appreciated.
Jonny042 03-05-2021 07:54 AM
Seems to be pretty common. You'll want to make sure you don't have any vacuum leaks, but raising the base idle speed will help a bit. Just turn it out a bit at a time until the problem is lessened.
proporsche 03-05-2021 08:59 AM
check your fuel mix if it is not a little too rich and i would set the idle at 900 i like it there better
Ivan
