Idle Bouncing
I have read some threads on this, but I still don't have a clear answer. My '84 3.2L starts fine and idles correctly (once warm) at about 850 rpm. However, if I hit the accelerator and then let the rpms drop back down, the idle hunts and surges (feels more like huffing and puffing) for a few seconds within a range of about 600-900 rpms until it settles back to about 850. Idle control valve?? Your collective wisdom would be appreciated.
(man/dude)
Seems to be pretty common. You'll want to make sure you don't have any vacuum leaks, but raising the base idle speed will help a bit. Just turn it out a bit at a time until the problem is lessened.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
check your fuel mix if it is not a little too rich and i would set the idle at 900 i like it there better
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
