msd versus coil
69 911e rebuild, coil or msd? Is the msd that much more reliable/durable? Opinions???
What are you running Ian? Thanks Gents!! |
I run the msd coil with programmable ignition box. I locked out the distributor and programmed a better timing curve in it.
Get the high vibration coil if you go msd. Sent from my iPhone using Tapatalk
Derrick |
