RETIRED
Fan belt change
Well after 20 years the belt started screaming. Belt dressing helped to get her home.
What a PITA to replace. 3.6 in an SC. Pulled the pulley off and had to cut it as two 13mm bolts that held the custom exhaust I have were in the way. NFW that the new belt was going on easy. If it had went on the road I’d be coming home on the flat bed. On my back with my new non recall Craftsman Jack stands, I was able to back the studs out to slip the belt over the triple pulleys on the back end of the crank. Cleaned off the debris on the pulley from the dying belt and proceeded to bolt everything back up. Of course I dropped the stainless steel Allen head down in the gutter under the aforementioned triple pulleys. Two of which don’t do a thing. Had to fashion a fishing tool out of a wire coat hanger. They don’t make them anymore BTW. But I found one in my roomies closet. 45 minutes fishing the damn thing out to at least see the stoopid thing. Got it to where a needle nose could grab it. Last fastener. Fired up. Head to Autozone Make model and year? Read the farting part #! We don’t carry them funny furring’ car stuff! Crap. Amazon 24 bucks.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
![]() I hear you brother. This is why I moved away from SS hardware where it is not essential. Magnetic fishing is much easier.
RETIRED
Looks pretty and doan rust. Bought it.
a day in the life .......
RETIRED
I'd sawzall the two extra pulleys if'n it didn't screw up the balance.
Stainless steel fasteners in a car? You're nuts, crazy, stupid or all three.
I have a standing rule when I work on a car. If the stainless steel nut or bolt comes off the car, it gets replaced with regular steel. Don't like that? take it someplace else.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
