1984 3.2, actual horsepower when new
I have a 1984 3.2 Targa with the 930-21 engine (sticker say 93021-64E).
I was pretty sure this is a 207hp engine, however, i just saw that the owner manual states: Net-horsepower, SAEJ1349: 200 hp / 149kW at 5900 rpm Anyone know how the 207 hp / 152kW was calculated? |
The 207hp is measured using the DIN standard which is measured at a higher pressure and lower temperature than the SAE standard that gives the slightly lower 200hp reading.
I see, anyone know what the owners manual say for the 930/25 (US 217hp) and the 930/20 (ROW, 231hp) ?
here is a list from factory specification
there you should be able find answers... Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
930/21 Max engine power to DIN 70020: 207HP Max engine power to SAE J 1349: 200HP both @5900 Max torque to DIN 70020: 260NM Max torque to SAE J 1349: 251NM/185lb-ft both @4800
207 in a Carrera = dog's bollocks
180 in a lighter weight SC is just the dog part. have i got that correct?
