Early turn signal stalk light issue
I am in the midst of doing a early 911 column conversion on my 914. The issue is that turn signal work fine. I can even pull back on the switch and get the lights to turn on. I have 12volts at the red wire as I should. However I never get power to the yellow or white wires that feed the headlights high and low beams.
So this happens with 2 switches that I bought used. Is there a rebuild procedure? If I ohm it out there is no continuity between the red and the white or yellow leads . Any thoughts?
Ben
89 944,85.5 944
914-6 2.4s GT tribute.
914-6werkshop.com
Old 03-25-2021, 11:30 AM
Prestallion's Avatar
Are you familiar with the turn stalk issue?
turn signal switch quick fix pictures
Mine had a similar issue to yours. I ended up cleaning the contacts with qtips and picks and was scraping corrosion off the contacts. Works fine now.
Old 03-25-2021, 12:32 PM
