HarryD's Avatar
Attaching the Rubber Insert in the Klein 21
The rubber insert that hold the spark plug inside my factory spark plug tool decided to separate from the metal tool. It does not appear to be damaged. How do I reattach so it does not come off when I install a spark plug.
TIA.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-24-2021, 02:24 PM
proporsche's Avatar
I used similar rubber hose size wise(you can modify it a little with a grinder on the edges),pushed it in so it is snug and use zep45 lubricant spray in the area where the plug goes....the dry rubber will stay in place..
Ivan
1985 911 with original 501 761 miles...807 506 km
Old 03-24-2021, 02:36 PM
Here's a basic question. Is there a source for new rubber?
Old 03-24-2021, 03:40 PM
I glued my old rubber back in place with that yellow, 3M rubber weather seal stick-em goo. Seems to work good on rubber to metal.
Old 03-24-2021, 08:08 PM
And then put a schmeer of dielectric grease inside the rubber so the plugs won't pull it out again.
Old 03-25-2021, 07:32 AM
HarryD's Avatar
Thanks smadsen. I will try a smear of the yellow goo.
eastbay, sounds like a good idea to help the plug separate.
Harry
2020 MB E350 4Matic
Old 03-25-2021, 01:08 PM
