What part is this?
Need some help identifying this 3 ended metal tubing piece on the back of the engine. This is a '79 engine.
As you can see in the second pic, there is some duct tape over it, not sure if it is to cover a crack or just to provide some insulation for the cover underneath it.
Any ideas?
Old 04-18-2021, 04:57 PM
Lash
CIS system, Continuous injection system. Changes made each year to CIS.
For starters see URL
https://jimsbasementworkshop.com/CIS/pages/fuel_hoses.html
Lash
1963 356 T-6 Normal Coupe
1972 911 T Coupe ..... Sold
1972 911 S Targa ...... Sold
1980 911 SC Coupe Weissach
Old 04-18-2021, 06:11 PM
ROW '78 911 Targa
timmy2's Avatar
Pipe from AAR and AAV to airbox for cold start.
Probably a hole worn in it looking at the top of the air deflector it was rubbing against for 40 odd years.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-18-2021, 10:58 PM
Red Line Service
Marc Bixen's Avatar
https://www.pelicanparts.com/More_Info/91111027701M253.htm?pn=911-110-277-01-M253&bt=Y&fs=0&SVSVSI=0796
https://www.pelicanparts.com/More_Info/91111027701OEM.htm?pn=911-110-277-01-OEM&bt=Y&fs=0&SVSVSI=0796
Marc Bixen/Red Line Service
West Los Angeles, Ca.
www.redlneservice.net / info@redlineservice.net
Podcast:"Marc Bixen Live"
https://www.youtube.com/channel/UC4DPQbCjH3OQ_h1iUcsrFfA
Old 04-19-2021, 01:58 PM
Thanks for the input!
I will peel off that duct tape and see if the pipe is not damaged. If it is only to protect the air deflector, I will wrap it up again
Old 04-20-2021, 12:54 PM
Designer King
Paulporsche's Avatar
I had a hole developing there. It was about 1/4" in diameter and all that was left was about a paper thin spot of material. It was so thin that I could "flap" it with my finger.
I JB welded a portion of a Swiffer handle over the hole. It had the right curve to suit the aluminum tube. It also appeared to be steel so I think it will last at least another 40 years. I am not afraid of any galvanic action since the epoxy sat between the 2 pieces.
I also glued a piece of rubber between the tube and the part below to act as a cushion.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-21-2021, 10:52 AM
