Alternative for factory Heater Tube in rocker?
Hey Guys,
Tearing into my rocker panel and I'm going to have to replace my heater tubes. Seems like there could be an alternative here. I would think there would be tons of different types of heating tubes/pipe that would work. Not sure if it really needs so much insulation? Since the heater tube attaches to the metal tubes that come up through the foot well area and also in the rear that run back to the flapper valves or what ever you call those things... I don't see why I could not even just weld a metal tube there. Or use the same type of tubing that runs from the heat exchangers. Not sure why you need all of the insulation, nothing to catch fire and heat is only on when valves are open. Has anyone ever used anything else? Thanks, Rodney
Rodney Nelson - '72 911T (Undergoing Full Resto), '82 SC (Grand Prix White) Gone for 20 yrs and now back, '86 951 (Guards Red) Caught Fire, '71 911T (Tangerine) Sold, '72 911E (Grand Prix White) Sold, '86 951 (Black) Sold, '79 SC (Grand Prix White) Sold, '71 911T (Irish Green) Sold |
Take a look at the DDK / Restorations threads, they deal with the heat tubes all the time over there, seems like every build. Lots of good info.
Could you please send me a link to one of their threads? I searched for DDK bot could not find anything.
Weekend weight loss projects...please Id these engine parts for me
Weekend weight loss projects...please Id these engine parts for me Quote:
1977 911S Targa 2.7L (CIS) Silver/Black 2012 Infiniti G37X Coupe (AWD) 3.7L Black on Black 1989 modified Scat II HP Hovercraft George, Architect |
I assume your MY engine has these parts?
The A/C compressor mount bracket is a hunk of thick steel bolted onto the driver side rear corner of the engine. It mounts to the crankcase, valve cover (?) and a couple of long studs on the chain box cover. If not used, I'd remove it and save about 4-5 lbs. The engine-mounted blower forces ducted air through the driver side sheet metal just below the rear cross mount to that 8 lb. aluminum distribution manifold, then to each heat exchanger where the air is heated, then to each cabin heater valve. It's under no stress other than heated air. The alternative is to back date the hot air system parts used up to '73 (see archives). It's easier done if the heat exchangers are also backdated along with factory sheet metal Sherwood |
Here is one:
https://www.ddk-online.com/phpBB2/viewtopic.php?f=28&t=68115&start=15 If you look around on the other threads there is more coverage |
I would rather be driving
I would think a hard silicone tubing would work great there. heat resistant and firm enough not to sag.
I refer to the same reinforced stuff that intercooler connectors are made from. Not sure if you can get it in long enough lengths. Something like this... (choose the 4 ply versions of right ID) https://www.siliconehose.com/silicone-straight-hose/ The factory material is not really heavy. I think it was used to prevent heat transfer into the longs and across carpet. Not sure that is a bad thing except for the life of the glue holding carpet in place.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Silicone is a good material. However, expensive. Prices in that link are per inch.
Thin wall al. tube with silicon hose end connectors would be an option. Wrap for increased heat insulation. Source silicone via ebay vendors. Sherwood |
