Question on steering rack.
I took my steering rack off and played with it a bit last night. Coming into pellican and see people rack has some bushings/spacers on each side but mine doesn't. Is it because they are diff year, or mine is simply missing something?
Pic from Autoban SteeringRack4_zps59b7119f.jpg Photo by Pacer42Z | Photobucket Mine Mine
Fat butt 911, 1987 Last edited by rnln; 11-05-2015 at 01:28 PM.. |
Reiver
You are good...the pic you reference shows a problem the guy is working with. His rack had a seal let go and the inner elements are coming out that side.
Your rack looks fine and you do have those parts but they are behind the inner seal at both ends.
De Oppresso Liber Strength and Honor 5th Legion |
Thanks Reiver,
How about the way the sharp tilted? Is it ok or does it have to be perpendicular to the rack?
Fat butt 911, 1987 |
Reiver
Probably they all eventually look like that....mine works too well for me to take it out for a rebuild even after 255k miles. Tight as a drum.
now, I am back to clueless. I am trying to trace a creaking noise on turn. After taking everything apart, a-arms looks good, ball joins look good, aluminum cross member look good, now steering rack look good. What else... sigh.
Thanks Receiver
Member 911 Anonymous
The weight of the SHAFT and age of the rubber cause it to deform, as long as the inner parts are not torn or damaged you are good. The Squeek could be from lack of lube
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
I will open it up to see how it is.
Shaft, sorry guys I keep saying "sharp" Thanks.
Fat butt 911, 1987 Last edited by rnln; 11-05-2015 at 04:12 PM.. |
Try a shot of ATF in the ball joint boot. 10 cc or so.
2013 991.1 Carrera S Cab 2004 996 Turbo CAB X50 sold 2003 996 cab 6 speed Sold 1972 RS 3.2 twin plug short stroke crank fire, roll bar, sold DE instructor since 1985 |
will do, thanks Frank.
On the rack, should I add grease or ATF inside the rack?
There are also a pair of bushing's you can add to the turbo tie rods called the "Tire Rub Prevention Kit " Elephant Racing |
Tire Rub Prevention Kit | Porsche 911/912/930 But not what you are referring to, I guess. That rubber connector is like a guibo / flex joint I think. You might want to just change the orientation of it 180 degrees. Pelican might sell new ones. Replace it if it has cracks etc.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats Last edited by Kraftwerk; 11-05-2015 at 08:08 PM.. |
I took the shaft/rod and bushing off. Bushing looks good, but one thing i didn't expect is the shaft/rod. The images of the shaft below are at the collar where the needle bushing should be
To me, there is no way this rod can be crack/broken with our hand force. I don't feel like it is a cast mark, especially at this location. Can it be a defective item? If it's yours, would you put it back in or get a new one? Thanks. ![]() ![]() ![]()
Fat butt 911, 1987 Last edited by rnln; 11-06-2015 at 09:58 AM.. |
no pics
That looks bad, at the very least questionable. Just put a new one in to be safe. This is not an area where metal fatigue will be your friend.
jt '83 SC '96 M3 6 Bicycles 2 Sailboats |
If you were an AXer or Track Guy, I would say replace it. But I think you are fine.
Just make sure you place bearing grease there and the needles. That area sit on the needle bearing covered by the rubber donut type bushing, it is meant to be flexible or you will feel every vibration on the road. Mine also looked horrible but I do not recall it having a mark like yours. Maybe one of the master wrenchs can chime in???
Wow $171 for a new shaft?
it doesn't look like it's was welded together (after it broke). So Porsche technician would install a steering component like this? Or maybe termites :lol:
Enthusiasm > Expertise
Buy a used shaft for $25-50, unless the only driving you're doing is in and out of the garage. A failure of your ability to control the direction of the vehicle is an absolute catastrophe anywhere else.
Red Dog Motorsports |
Looked at it personally today. It appears to be surface only deterioration. I think he will be okay but it is not my car. It will not interfere with the needle bearing since it is radial.
I think he will replace it to be safe.
Reiver
Like you said probably no issue but that is just not a place to accept 'probably'...same as in the brake system. 100% or better in control/braking
Thanks Draco for spending the whole day at my place.
Thanks reciever, reddogmotrsprts, If you know any place I can get a used one, please let me know. I appreciate it. Thanks.
