-   -   shifting and double clutch instruction (http://forums.pelicanparts.com/porsche-911-technical-forum/1090147-shifting-double-clutch-instruction.html)
KNIGHTRACE 04-03-2021 06:06 PM
https://youtu.be/0TYD4aOvN80
Larmo63 04-03-2021 10:08 PM
Nice video that every Porsche driver should watch!
Thanks Ian.
SoCalSK8r 04-04-2021 05:23 AM
I learned a ton with that video, thanks for sharing!
Aircooled4evr 04-04-2021 07:01 AM
Wow! It's SO cool to actually UNDERSTAND what you've been told to do!! :)
911TerryT 04-04-2021 07:53 AM
I am in my 60's and learned how to drive with manuals. I drove a 5/4 split International tri axle when I was 16 for a after school job. I also have driven 13 speed with split axle, non sync 1st gear box's etc. I will send this video to my friends and family that drive a manual as many good points are made here on the how's and why's of shifting. I don't track any of my cars but I do drive spirited when the opportunity presents(where I know the road and risks of exceeding the speed limit) and use the double clutch/heel toe technique. I will mention I also will skip a gear when upshifting when I can(usually when I redline the gear I am in and on a flat/downhill slope) I feel its important to know how to drive a manual as I think it makes people a better driver(If you desire to go to Italy and drive the Amalfi coast good luck renting a automatic).
There is a lot of debate on what's better to drive...a manual or PDK for track and spirited driving. I am lucky enough to have both and I enjoy both for what they are.
If I could only have 1 to drive as my fun car it would be a manual air cooled.
Everything changes over time but I hope by sons will have a desire to rip some roads in a manual when they are my age.
Thanks guys for taking the time to put together a very informative video.
d15b7 04-04-2021 08:22 AM
this is probably the best explanation (and made understandable for a 'regular' driver) that I have ever watched/listened to about the hows and whys of shifting, with fantastic visual aids too. exceptional! i'll be showing this to a bunch of my friends; great job guys!!
kent olsen 04-04-2021 08:30 AM
All my vehicles with the exception of my motor home are manual. 65 Vette, 72 Porsche, 93 Classic Mini and my 2001 Dodge dakota. God help me if I trip over my cat.
I learnt to heel/toe and double clutch, and rpm match when I was young, I'm 77. In all those years I have never used up a clutch. Now if I pull the engine or transmission I will always replace the disc but I've never even replaced the pressure plate.
faapgar 04-04-2021 10:54 AM
kudos to Ian
I can not even imagine how many people you helped with this video.Every time I rebuilt a gearbox for a customer I would drive it for 100-200 miles and double clutch every shift to seat the synchros.You have done a great service with this video.Keep them coming.Ciao Fred But you have to remind them it is fun to drive this way.
William A 04-04-2021 12:38 PM
Been fortunate to drive many times with Ian. He knows his stuff, and is passionate to pass it on.
Lead/follow with Ian is a blast and educational. He sees so much, even when he is leading while watching you in the mirror.
As a passenger in his car, and it doesn't matter what car it is, you witness and marvel at his impeccable technique.
If Ian was as smooth with women as he is driving a car, Wilt Chamberlain and Magic Johnson would be competing for a distant 2nd! :)
KNIGHTRACE 04-04-2021 01:32 PM
I think They did a good job explaining it and thought it was good to share. I hope this helps some people and brings some positive news/information. William Knight
Jonny042 04-04-2021 02:53 PM
Great video!!! - I learned to double clutch from watching an instructional video from Jim Russel Racing school when I was in my teens. By the time I actually got to take the course at the school I was proficient enough at it that I could drive the cars properly - dog boxes (like all REAL race cars have) don't have synchros at all.
The video is of great benefit for sure!! So few people know how to properly drive a manual trans car..... actually understanding the mechanics of what is happening is key and this video shows it well.
Mahler9th 04-04-2021 05:06 PM
I learned how to double clutch in the early 80's in my first car, and MGB. I learned from the Bondurant book... Bob Bondurant on High Performance driving. It had a picture-by-picture set of illustrations.
Since I first learned, I have always double clutched when performance driving on the street, in AX and on the track.
I found that book to be a great resource.
My number one resource has always been the Skip Barber video Going Faster!
Harry Reynolds does a nice job going over double clutch downshifting in that video.
Of course as folks know, the parts longevity of the synchromesh system used in many 911s is benefited by double clutching. Some do not know that many types of racing cars "back in the day" did not have any type of systems to help downshifting. For example the age-old Hewland boxes.
KNIGHTRACE 04-04-2021 05:50 PM
Many people do not know how to do this, most often it is explained incorrectly. I think the use of the transmission really helps.
jmc1313 04-04-2021 07:22 PM
Many people don’t know this but you can shift without depressing the clutch, just match road speed and engine rpm/gear.
Example, if you are driving at 40 mph in 2nd at 4000 rpm, let off the throttle and slip it into neutral, let the rpm’s drop to 2500 rpm and slip it into 3rd gear.
The same for downshifting, going 40 mph in 3rd at 2500 rpm slip it into neutral and rev the engine to 4000 rpm, slip it into 2nd.
You do need to find out what the splits are for each gear but once you know that it’s pretty simple.
The point they made in the video about weight transfer is important, you will not believe how smooth the drive is when you match road speed/rpm/gear.
John
smadsen 04-04-2021 09:05 PM
What a great instructional video!
I've found, at 6'4", foot placement is difficult to accomplish because I can't come anywhere close to straightening my right leg in the Porsche ('82). You need to monkey with the pedals (brake/throttle) so that when the brake pedal is depressed, it stops just a little proud of the throttle at idle. You need to get to the throttle for the "blip", but not pick up the throttle by accident under braking.
After you practice for a while, the process becomes seamless, and second nature.
In the Formula Ford with the Mk8/9 Hewland the process was the same, but you didn't use the clutch, expect to get going. I always used the clutch on the upshifts, now I understand why it never felt quite right. To hard on the internals. Downshifts, 4 to 1 were always very smooth and fast, generally under full brakes, no clutch.
jmz 04-05-2021 09:57 AM
Nice Foot work Fred Astaire! ...cool video.
pampadori 04-05-2021 10:56 AM
@Jmc1313 if you do the clutchless downshifts you are suggesting you're not getting both shafts to the same speed and you're asking the syncro rings to sacrifice themselves to match the speeds for you.
jmc1313 04-05-2021 01:50 PM
Either I didn’t explain it well or you misinterpreted it. When you double clutch you re-engage the clutch when you let out the clutch in neutral, that’s what matches the engine and road speed. The only difference is I don’t push the clutch in to move it in/out of gear. As long as you match the engine speed to road speed in the proper gear it will slide right in, smooth as butter.
Millions of truckers use this method driving billions of miles.
John
robertmark 04-05-2021 02:23 PM
Great Vid Ian. You know your s**t. Now move to Indiana so I can take advantage of your knowledge.......damnit!!!!
911pcars 04-05-2021 04:28 PM
John
Problem is, if the clutch is up (engaged), there's no way to independently change the rotation speed of the input shaft to match the rotational speed of the output shaft in a just-shifted lower gear. Unless the gearbox is in neutral during that rev, the input shaft is still connected to the last gear selected.
Depress clutch (pedal down) to disengage the engine from the rear wheels and momentarily shift into neutral. Re-engage clutch (clutch pedal up). This allows you to blip the throttle to raise engine and input shaft rotation speed to match the gear speed in the next lower gear. A quick clutch pedal down to disengage before revs drop too much while shifting to the next lower gear should hopefully closely match engine speed to rear wheel speed as the clutch pedal re-engages (pedal up). You want to end up with the engine revs the car would be at the same car speed. If not, try again.
Practice on a deserted road and practice using the higher gears. There's typically less gear reduction e.g. between 4th and 5th than 2nd and 3rd and thus fewer rev difference to match. For example:
Vehicle speed...........RPM
30 mph in 4th gear...2000.... double-clutch from here...
30 mph in 3rd gear...2600 ... to end up here w/o discernible vehicle dynamics
Sherwood
jmc1313 04-05-2021 08:11 PM
You are doing the same thing I am doing. When you shift into neutral the gears are disconnected, let the engine revs drop to the correct rpm, shift into the next gear. Sam with downshifts, shift into neutral, increase the rpm’s to the right speed, shift into lower gear, no clutch required. You need to hit your rpm’s accurately but when you do it’s the smoothest ride possible.
Solamar 04-05-2021 08:21 PM
Forced to learn the above as a cheep teenager with a VW bug and broken clutch cable.
Came in handy later in life learning to drive tractor trailers. Clutch is only to get started, then it's just rev match shifting, and yes, same principle as double clutching.
icarp 04-06-2021 10:52 AM
shift
JMC, I'm not sure I agree with your explanation . The use of the clutch and the double clutch offers the smoothest shifting possible . The shifting of a racing dog box ,
Hewland , or the like is still best for the trans longevity to use the clutch on the down shift . Clutchlees upshifts are the fastest , but this is a racing transmission , torn down and rebuilt on a regular basis . So remember downshifting is not an emergency , just be smooth and efficient .
Shifting street gearbox without a clutch is possible , but not without wear on the inner parts .
So if you loose the clutch operation , you can still drive the car back to safety .
The purpose video is for the basic explanation of the double clutch operation, yes there are some modifications to the style and the execution . But for now lets stay with the basics .
Thanks for all the interest
Ian
jmc1313 04-06-2021 12:57 PM
People seem to think I’m advocating just slamming the transmission into gear. It’s more of a zen experience, rpm’s rising and falling in response to the input from the driver and road. When the speed is matched there is no wear on the gears. Next time you are on the road listen to a semi accelerate from a stop, there is no lurching or grinding of gears. They are only using a clutch to start.
I’ve put 250k miles on a Toyota Celica and a million miles on a truck without a transmission or clutch problem.
Try it, you might be surprised.
icarp 04-06-2021 04:38 PM
John, jmc1313
I made a video to introduce an explanation of the concept of double clutching . I have been teaching racing, and restoring racing cars for 47 years , in a wide variety of cars I might ad , from the early 1920's to modern GT and formula cars . How about a Wilson Pre Selector Gear box ? In my last post, I think you missed my acceptance of your point that some racing transmissions love shifting without the clutch . A motorcycle transmission loves to shift as well, without the clutch . I also agree that a syncro trans can be shifted without using the clutch . But choosing to shift the car without using the clutch is going to cause most people trouble . Also I did state it is possible to get your self home with a broken clutch operation .
Your truck trans is designed to be shifted without using the clutch. "designed to be shifted without using the clutch". Not "can be shifted" . I agree that synchronizing the speeds of the gears is key.
I mention that many times in the video
Just stating that some of "your" vehicles can be shifted with out using the clutch might be confusing to the readers . I am trying to appeal to the majority of the readers .
I wrote the Lesson for teaching our "Special Forces" on how to drive a manual trans car . It is part of a lesson plan that is considered a part of the ultimate lesson plan for all of our "Special Forces". It is a 6 day intensive program .
"Man Trans " is 45 minutes of classroom, then we had less than 15 minutes, per student, to teach each student every thing there is to know about driving a manual trans car . I'm sure there were things in the lesson that you were not aware of as well .
15 minutes to become familiar and proficient, with the entire process.
I am just trying to help the Porsche owner become more familiar with the art of shifting
Ian
MikeD930 04-07-2021 06:52 AM
Ian...I never thought about double clutching during upshift. I have yet to became proficient in double clutching including heel/toe while downshifting. Since watching your video I have a better understanding on how to do it properly and I will make an effort to double clutch more often if not every time. Thanks for sharing your knowledge with us about double clutching.
icarp 04-07-2021 07:51 AM
shifting
Mike , thanks for the nice words . Double clutching on an upshift , is for helping a bad or worn syncro . I suggest the practice of double clutching on an upshift as a way to increase the opportunity to develop the skill set , the more you do it, the better you get at it . So double clutch on every shift for a while . Practice slowly.
As with all driving skills , the more you think about them , the better you get.
I try to think of all of my driving skills at some point while I'm driving .
Ian
alexandervdr 04-08-2021 06:04 AM
great video, takes the macho and nonsense out of the double clutching, to replace it with facts, logic and method ;)
kent olsen 04-08-2021 08:24 AM
When my boss bought a Freightliner tractor and trailer (16 speed) to carry the race-car his son and I went out to learn to drive it. Up-down shifting without the clutch was difficult. Sometimes I would just barely hold a little tension on the shifter so I could feel the speed of the gears and slip it into the next gear as I felt it slow down. My biggest problem was slowing for a turn where I needed to drop 2-3 gears. I could never seem to find the right gear and remember times when I had to stop and start over. No one ever suggested I just use the clutch, hmm.
NY65912 04-08-2021 09:42 AM
Many years ago I would drive a 1960 B model Mack oil truck. Very easy to up-shift w/o the clutch.
Always dbl clutched down shifting as it was a crash box. It had an incredibly tight gear box.
Thanks for the video and thanks to Tom for presenting it on Garage Time
Cheers
911pcars 04-09-2021 04:03 PM
Double-clutching on upshifts isn't necessary. The gear ratios decrease during an upshift 1-2-3-4-5, thus engine revs gradually decrease during upshifts. Thus as the engine revs decrease from the previous gear, it will gradually match the revs of the next higher gear selected . You should be able to feel that engagement threshold while holding the lever against the synchro as the revs decrease.
OTOH, reving the engine (in neutral) while double-clutching during a downshift increases the matching revs as each lower gear is selected.
Sherwood
Lyle O 04-10-2021 01:41 AM
I watched the video and read all of these posts, and took my car out to try this. It is not easy changing 45 years of trained muscle memory! I have a lot of practice to do to get even close to feeling comfortable...
pampadori 04-10-2021 04:41 AM
Sherwood, double clutching on the 1 to 2 upshift is the only way my dogs don't grind. I am in need of some 915 work but have a 2nd baby due this month so car is on the back burner, so to speak.
It may not be necessary but it is the only way to get the two shafts in the trans to match speeds and make the shift free from grinds.the falling rpms of the engine won't help do that.
hitch911 04-10-2021 06:35 AM
I too have been practicing as Ian suggests. He mentioned it'll take 3-5 years to get really good at it. Probably spot on, like changing your golf swing. A swing fix may work on the driving range and even on the first tee but how about on the 72nd tee of your club championship with a 1 shot lead? For me to make downshift double clutching instinctive and natural will take many hours of practice. Love the reward of a good shift though and something new to work on. Thanks for the video and sharing your knowledge of shifting fundamentals.
911pcars 04-10-2021 09:01 AM
If you allow engine revs to drop during the shift, the worn synchros will struggle to match revs. Try shifting before the revs drop below the rev zone it would be at the current car speed. If double-clutching helps, the above procedure is essentially equivalent. At the end, do what's necessary to get in gear and minimize add'l wear.
Hitch,
D-clutching is just another driving skill. Not necessary for basic car control, but suggested for better car control and to extend service intervals. How long does it take to master golf, culinary skills, playing an instrument .... or curling? It's a continuous learning process, especially for skills you care about. It's been loosely said that Jack Nicklaus, at his peak, would still hit 500 practice balls a day.
S
josephvman 04-10-2021 10:09 AM
I have no issues with heel/toe in my other cars, but the pedal on my 3.2 make it very difficult. Anyone else struggle with this on their air-cooled car?
hitch911 04-10-2021 11:58 AM
Sherwood, Nicklaus worked very hard and then there's Hogan who said there weren't enough daylight hours in a day to practice all the shots he needed to practice. No substitute for hard work for sure. Will take your advice and find a quiet country road and practice in the higher gears for starters. I feel somewhat duty bound to improve my skills so my carrera benefits too. Fun stuff.
Alan L 04-10-2021 12:17 PM
Great video - well explained.
I had the misfortune some yrs ago to break a clutch cable on my SC. Normally you would think of a lift home for the car. I was only part way in to a long journey in a remote area. I drove it several hundred miles with no clutch - and not flat straight road. Twisty up/down country road and a few towns in between. Used the wide torque band of the 3.0 as much as possible to conserve shifts, and my gearbox - but got to know where the revs needed to be. And with a little pressure on the gear lever you could feel when it wanted to slip in. Those synchro bits in a 901/915 box are $$$expensive.
That box some 10-12 yrs later is still in the car and performing perfectly.
What had happened was the clevis pin holding the fork to the pedal cluster had worn thru. Subsequently, each pedal cluster I have pulled apart has been in bad shape. There are plastic bushes that are usually badly worn, and the clevis pin always has wear also. Something to check. PITA to get to - which is why they don't get checked. I replaced the SC clevis pin with a cut down high tensile bolt. Not sure if it was the right thing to do - but it is still all holding together OK.
Alan
911pcars 04-10-2021 01:55 PM
The way the pedals are arranged, it's easier to toe on brake and heel on gas pedal. The gas pedal is typically not on the same, preferred level as the brake, but it can be raised or a block installed to approximate the brake pedal at some applied position. Don't lower the brake pedal. Not recommended to run out of range with brake to spare.
One of the Porsche aftermarket companies has a fully articulated, hinged and turn-buckled gas pedal that should satisfy all manner of foot sizes, angles and bone spur projections.
Alan L 04-10-2021 04:11 PM
Bear in mind you are normally depressing the brake pedal a fair bit when heel/toe on the downshift. It should line up approximately in the area of the gas pedal. I use the ball of my foot on the brake and sort of roll my foot over a bit - using the heel and lower side of the foot on the gas pedal. The top of the gas pedal shouldn't be too far away from the brake position. it maybe a case of adjusting how you are using the foot. Try some alternate techniques. You don't need to reach near the bottom of the gas pedal. Not like normal driving where you rest the heel of the foot on the floor and position over gas pedal.
Alan
